When clicking on an item or going to logbook it doesn’t show history. Just continuously loads for no reason…
Reload the page.
I reloaded the page, restarted the home assistant, and tried different browsers and devices. Wont load
Check Settings → System → Logs.
I backed everything up onto a flash drive then it started working. I was going to delete it. It does actually take 30 seconds to load though is this normal or should I routinely delete the log?
What are you running HA on and how large is your recorder database?
