My temp sensors in history dont both show a linear reading even tho both are setup the same and both messages come in at the same time. Sump temp looks correct.
Are you running the latest version of Home Assistant? This bug was solved in one of the latest versions, at least 0.60 should be working ok.
58.1 , Thank you
