History of state is "[object Object]"
Hi all,
I’ve noticed that some of my entities are showing a weird issue in their history. When I try to load a history for say, a light, I get [object Object] where the history should be:
Any ideas what could cause this? When I look in the more history for that entity, there is no history, even though it’s available and been used regularly.
Thanks!
Post a screenshot of Dev tools → State for this entity
Here you go:
I am not an expert on “light” entities.
But I find rather strange to have a supported color_temp and null value for this attribute.
Probably a code for more-info for lights considers this entity as a wrong one.
It’s happening on basic sensors, too. Like:
Also, for that light, the color temp state is null when it is off.
On what do you see on more-info for this sensor, same “object object”?
“No state history found.” No matter what date range I choose.
However, other sensors like this one provide history just fine:
No history could mean that your entity is excluded from recorder.
What you demonstrated was “object object” glitch - and that is why I suggested you to post a screenshot what you ignored.
I use default_config, then recorder with just the commit_interval set to 15s. I.E. no exludes.
So, can you still see no history for any entity?
Can you see any errors/warnings in Log?
Do you have HA version updated?
I see history for some entities, not others (examples in screenshots above). No errors in the logs, and using the latest tag for HA in docker.
Do you found a solution to this problem? It have it right know and no ideea how to solve it
