History page does not load
It typically takes months for frontend issues to get looked at and fixed.
hmm, it might be that since many details are being moved to the frontend, the team is simply overwhelmed. It might be a good idea for the team members to have a discussion on how to mitigate that… things piling up is not a good sign, and issues on issues are a nightmare to solve.
Hope some internal signal can be forwarded here.
Hopefully with the additional NC employee that has frontend experience they can begin to knock some of those issues over
Hope so as well, but I think that the prioritization is currently not on solving issues to get things working (again) but on changing the UI - needed or not needed. See changes in configuration menu, developer tools, discussions in frontend-github, etc.
The will be solved in 2022.7 via https://github.com/home-assistant/frontend/pull/12824
Thx so much. Did you now split after each x items as I had in my (non technical) mind as a potential solution?
Without going into the details, the short answer is yes
