Noy1122
(Noy Jakubovits)
January 16, 2022, 1:40pm
1
Hello, I have total energy sensor but I dont see the history of sensor…
This is the config of sensor I made
template:
- sensor:
- name: "צריכת חשמל נוכחית"
unit_of_measurement: 'W'
state_class: measurement
device_class: power
state: >
"{{ ( states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_d8bfc01a1512_power')|float(0) + states('sensor.shelly1pm_84cca8a824e8_power')|float(0) + states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_98cdac1f5218_power')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.shelly1pm_98cdac1e2174_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.shelly1pm_e8db84d7a30e_power')|float(0) + states('sensor.tasmota_energy_power_3')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.sonoff_1000cab798_power')|float(0) + states('sensor.sonoff_1000cab589_power')|float(0) + states('sensor.tnvr_mqlkht_power')|float(0) + states('sensor.tasmota_energy_power_4')|float(0) )|round(0)|int(0) }}"
and that what I see
someone know what can be the problem?
thank you
123
(Taras)
January 16, 2022, 4:55pm
2
The value the sensor reports should be numeric, like 832
, but it is non -numeric because it includes double-quotes "832"
The reason is because you have defined a multi-line template, which doesn’t require outer quotes like a single-line template, but have included outer double-quotes. As a consequence, the double-quotes become part of the reported value. Remove them and execute Reload Template Entities. You may have to wait several hours for new, numeric data to be reported before it appears in the graph.
Noy1122
(Noy Jakubovits)
January 17, 2022, 11:32am
4
I tried to remove this but it still not working
123
(Taras)
January 17, 2022, 1:03pm
5
Post the sensor’s revised configuration.
Noy1122
(Noy Jakubovits)
January 17, 2022, 1:09pm
6
I think im not remove the right quotes
I tried 2 options
1
- sensor:
- name: "2צריכת חשמל נוכחית"
unit_of_measurement: W
device_class: power
state: >
"{{ ( states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_d8bfc01a1512_power')|float(0) + states('sensor.tvrh_mqlkht_power')|float(0) + states('sensor.slvn_vpynt_vkl_lvqly_power')|float(0) + states('sensor.dvd_power')|float(0) + states('sensor.shelly1pm_84cca8a824e8_power')|float(0) + states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_98cdac1f5218_power')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.shelly1pm_98cdac1e2174_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.shelly1pm_e8db84d7a30e_power')|float(0) + states('sensor.tasmota_energy_power_3')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.sonoff_1000cab798_power')|float(0) + states('sensor.sonoff_1000cab589_power')|float(0) + states('sensor.tnvr_mqlkht_power')|float(0) + states('sensor.tasmota_energy_power_4')|float(0) )|round(0)|int(0) }}"
2
- sensor:
- name: "1צריכת חשמל נוכחית"
state: >
"{ ( states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_d8bfc01a1512_power')|float(0) + states('sensor.tvrh_mqlkht_power')|float(0) + states('sensor.slvn_vpynt_vkl_lvqly_power')|float(0) + states('sensor.dvd_power')|float(0) + states('sensor.shelly1pm_84cca8a824e8_power')|float(0) + states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_98cdac1f5218_power')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.shelly1pm_98cdac1e2174_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.shelly1pm_e8db84d7a30e_power')|float(0) + states('sensor.tasmota_energy_power_3')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.sonoff_1000cab798_power')|float(0) + states('sensor.sonoff_1000cab589_power')|float(0) + states('sensor.tnvr_mqlkht_power')|float(0) + states('sensor.tasmota_energy_power_4')|float(0) )|round(0)|int(0) }"
123
(Taras)
January 17, 2022, 1:20pm
7
You should remove the double-quotes enclosing the template .
template:
- sensor:
device_class: power
state: >
Noy1122
(Noy Jakubovits)
January 17, 2022, 1:45pm
8
Oh ok thank you!!! now its working!
Thank you man!
