I have created a helper called “body position” which tracks whether I am sitting, standing or laying down. Based on osha:s guidelines on prolonged sitting ( kProlonged (europa.eu)), I now want to get a notice related to their guideline “stand up for at least 10 min per 2 hours of sitting”.
So I created this sensor:
- platform: history_stats
name: Time standing since standing up
entity_id: input_select.body_position
state: "Standing"
type: time
start: "{{states.input_select.body_position.last_changed|as_timestamp}}"
end: "{{now()}}"
But this does not work as expected. I want this sensor to count the time when I am standing but it reports 0 when standing. Instead it seems to count when another body position state is selected after Standing. So for example it starts to count when I sit down, which is completely not what I want.
(I will then create an automation that stores the timestamp as soon as the sensor above goes from 10+ minutes to 0. And a notification should be issued when body_position is “Sitting” and the current time is two hours passed the stored timestamp.)
Thanks, but I still need a sensor. 10 minutes will be the required amount of standing, while 2 hours will be the accepted time without exercise. (If I sit for 1 hour, and stand up for 1 minute, the notification should be issued 59 minutes later. The one minute stand-up was not enough.) After the minimum 10 min standing, I also need to add a trigger to wait for state to change away from Standing. If not possible with history_stats, it seems like I will need two automations instead of one automation and one sensor.
# Automation 1 to set the start time for the 2-hour condition
- platform: state
to: "Standing"
for:
minutes: 10
- wait_for_trigger:
- platform: state
entity_id:
- input_select.body_position
- service: input_datetime.set_datetime
metadata: {}
timestamp: "{{now()|as_timestamp}}"
entity_id: input_datetime.latest_10min_movement
