Hi!
I have configured history_stats sensor counting number of MQTT movement detection based on other sensor:
- platform: mqtt
state_topic: "e-hallway-cat-toilet/detection"
expire_after: 86400
- platform: history_stats
name: "Cat toilet history"
entity_id: sensor.cat_toilet
state: "1"
type: count
start: '{{ now().replace(hour=8, minute=1, second=0) }}'
duration:
hours: 24
It is working well - counting till 08:01 each 24h and then reset to zero.
The problem is that after host restart (called by hassio service actually at 04:04 AM), the status gets “unknown” till stats are discarded at 08:01 AM and then it is working from zero again correctly.
I’ve tried to reload stats by calling service “history_stats.reload” as an automation after Home Assistant boot, but it doesn’t change anything.
I have turned off “auto_purge” of my recorder and trigger it by an automation after sensor reset:
recorder:
purge_keep_days: 3
auto_purge: false
Anyway, there should be data 3 days old which means it should not have any effect to my issue.
Is there any way how to restore the “history_stats” sensor value after host restart?
Thnaks a lot!
