Let’s see how a "count"
value is defined for "history_stats"
Case 1:
There is a ping device tracker for some PC:
device_tracker:
- platform: ping
hosts:
pc_ping_device_tracker: !secret pc_ip
count: 2
consider_home: 60
Now I want to check how many times this PC was unavailable a day:
- platform: history_stats
name: "PC unavailable today (tracker)"
entity_id: device_tracker.pc_ping_device_tracker
state: "not_home"
type: count
start: "{{ now().replace(hour=0, minute=0, second=0) }}"
end: "{{ now() }}"
If the PC is ON during a day, the sensor’s value is supposed to be 0.
And it is a 0 - so the "count"
value is defined properly.
Case 2:
There is a ping binary sensor for the same PC:
binary_sensor:
- platform: ping
host: !secret pc_ip
count: 2
scan_interval: 60
And the "history_stats"
name: "PC unavailable today (binary)"
entity_id: binary_sensor.pc_ping_availability_status
state: "off"
type: count
end: "{{ now() }}"
Case 3:
There is a "binary_sensor"
of "connectivity"
device class which is defined based on the "device_tracker.pc_ping_device_tracker"
defined above:
binary_sensor:
sensors:
pc_ping_availability_status_2:
value_template: "{% if is_state('device_tracker.pc_ping_device_tracker','home') -%}
{{ 'on' }}
{%- else -%}
{{ 'off' }}
{%- endif %}"
device_class: connectivity
name: "iiyama-1 unavailable today (test)"
entity_id: binary_sensor.iiyama_1_ping_availability_status_test
state: "off"
type: count
end: "{{ now() }}"
And just after HA restart this sensor is = 1.
Why?
Does this mean that the template sensor is zero during HA startup since it is not initialized yet?
Update:
That is my fault - I forgot that all my template binary_sensors are OFF during startup - this is seen in History.
Does it mean that I should not use template binary_sensor as a basis for the "history_stats"
sensor?
