Good day,
I’m experiencing the following error:
2025-02-24 09:34:32.483 ERROR (MainThread) [homeassistant.setup] Error during setup of component recorder: 'recorder'
File "/usr/src/homeassistant/homeassistant/setup.py", line 422, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 162, in async_setup
instance = hass.data[DATA_INSTANCE] = Recorder(
hass=hass,
...<8 lines>...
exclude_event_types=exclude_event_types,
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 186, in __init__
db_connected: asyncio.Future[bool] = hass.data[DOMAIN].db_connected
KeyError: 'recorder'
2025-02-24 09:34:32.485 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'history_stats'. Setup failed for dependencies: ['recorder']
Surrounding logs show nothing in relation to this. Startup and functionality of HASS is normal, however there is no history for any entities.
I’ve removed the DB, and it recreated successfully - so corruption is ruled out.
This is the only other post I’ve seen referencing this error.
TIA!
