History stop recording
The history graphs and history for the entities stopped recording on 2/2/18 at about 4:00 pm. I have rebooted, restarted and cycled power with no changes.
frontend:
config:
updater:
discovery:
conversation:
history:
logbook:
The configuration file has history in it. I did start getting an error this afternoon Socket error while discovering SSDP devices. Eight days later.
The only error that relates to history that I found in the Home Assistant.log file is:
2018-02-07 06:38:12 ERROR (MainThread) [frontend.js.latest.201801300] https://carb1.duckdns.org:8123/frontend_latest/panels/ha-panel-history-a9a928488e1755c7c3283c1de7d41d32.html:1:2801 Uncaught TypeError: Cannot read property 'getDate' of undefined
Anyone else seeing this problem? Thanks for any help.
2018-02-10_20-10-24
I went back to a snapshot that I saved the day before the history stopped and now the history seems to be working again. The only change that I had made was to add node-red but that was after the history stopped working.
There is a similar issue that someone else has entered under configuration.
