History tab not loading after upgrade
Hi girls and guys!
First post here, but I have been following for the last couple of years.
Running HassOS 7.0 on rpi4 with ssd
I’m kinda stuck on core 2021.8.6.
Last month i upgraded to latest core 2021.11.x. After upgrade i noticed that the history tab wouldn’t load. Just had the loading circle going on and on for ages. I can see state history everywhere else.
After som failed attempts i decided to roll back, and hope for better luck with next upgrade.
Now I’ve upgraded to core 2021.12.1 and experience the same. Can’t load any info on history page
I’ve tried:
  • Deleting database file, and rebooting.
  • Converting to mariaDB
None of the above have solved it. If i roll back to 2021.8.6 it loads within seconds.
Is it somehow the history integration that is failing? Does any of you have an idea to get me on the right track?
Your help is much appreciated!
Thanks!
/Jakob
Problem solved.
After converting to MariaDB i did not delete the old database. When doing that, everything suddenly worked again :slight_smile:
