Hitachi AC H-link with ESPhome
Hi everyone!
I’m glad to share an ESPHome component I’ve been working on for controlling Hitachi AC units through their proprietary serial protocol H-Link, making them fully integrated with Home Assistant - completely local and cloud-free!
This solution works similarly to Midea ESP dongles but with a few differences. It requires a step-down converter (12V → 5V) to power on the ESP board and uses the H-Link protocol, which is different from Midea’s.
I’ve also included basic technical details about the hardware in the README file, so feel free to check it out. I hope this helps anyone looking for reliable local control of their Hitachi AC units!
Cheers,
Max
Hi, excellent project.
I’ve recently integrated it into my own setup with a Hitachi RAS-70YHA2 unit. As part of the process, I documented the configuration and shared it here: GitHub - shardshunt/H-Link-Docks. It may be useful for others working with similar HVAC systems.
@shardshunt Thank you for the docs repo! I’ve included it as a reference in the README’s examples section.
By the way, the HY2.0 connector also requires filing on both sides, and I had to cut the connector latch as well.
It’s truly impressive that mass-market hitachi air conditioning units with an age difference of 15–20 years still use the same protocol - something not very common in the consumer segment today.
Hi @shardshunt
First of all, thanks for sharing your work on the H-Link Docks, it looks really interesting!
I was wondering: do you happen to have a 3D case design for the board? Or is it meant to be used without an enclosure (open setup)?
Would appreciate any info you can share.
Thanks in advance and keep up the great work!
Best regards,
Arthur
There is a handy spot at the bottom right of the heatpump to shove the spagetti so thats all i have done.
Thanks for your project,
I have a question, is it supposed to be compatible with any HITACHI AC Unit ?
I have a lot of HITACHI split, and I would like to control them with HA, this solution could be affordable. Here is my system :
  • HITACHI RAC-50FXE + HITACHI RAF-50RXE
  • HITACHI RAM-70NP4E and 4 unit HITACHI RAK-18RPE
  • Thermodynamic water heater HITACHI RAW35NHB + HITACHI TAW270NHB
They are compatible with the SPX-WFGXX cloud adapters, is that suppose to mean that they use HLink protocol ?
Hello @RD2,
I’m not affiliated with Hitachi in any way, so it’s totally up to you to test whether a particular model supports the H-Link protocol or not.
At the moment, it looks like there are many models that appear to be compatible, even quite old ones.
My advice is to first find a technical datasheet for the indoor split unit of your AC and look for an electrical wiring diagram. If it has a 6-pin connector marked as H-LINK (often referred to as CN7 in the documentation), there is a good chance that your split unit is compatible with this component.
For example, the RAF-RXE/RAC-FXE documentation mentions an H-LINK port, so there is a chance that RAC-50FXE + RAF-50RXE would be compatible.
I try it with a RAK-18RPE unit, with a ESP32 S2 mini,
But it doesn’t work. I have these messages :
I have these message either the device is connected to the unit or not.
I also tried with a classic ESP32 WROOM, I tried Rx0/tx0 and Rx2/Tx2, on one of them I had the same result as above, and on the other one, I had a different error :
But It doesn’t work either.
Do you have any idea where I made a mistake ?
ESP Home yaml :
esphome:
  friendly_name: Hitachi - S2
esp32:
  board: esp32-s2-saola-1
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "a4CVLjmDXPifbxrc1Of5wyQlGMdYs90n03yQU/xJUqI="
ota:
  - platform: esphome
    password: "3433cf267841f0c12df1c4fddec40287"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Hitachi--S2 Fallback Hotspot"
    password: "uigpCtaGx5JC"
captive_portal:
uart:
  tx_pin: GPIO37
  rx_pin: GPIO39
  baud_rate: 9600
  parity: ODD
external_components:
  - source:
      type: git
      url: https://github.com/lumixen/esphome-hlink-ac.git
      ref: 2025.7.1
    components: [hlink_ac]
climate:
  - platform: hlink_ac
    hvac_actions: true # Remove or set to false if you don't need HVAC actions.
    supported_presets: # Presets are disabled by default. Remove this if your AC does not support Leave Home mode.
      - AWAY
    supported_swing_modes: # Could be removed if your AC does not support horizontal swinging. By default only vertical mode is exposed.
      - "OFF"
      - VERTICAL
      - HORIZONTAL
      - BOTH
switch:
    remote_lock:
    beeper:
    auto_target_temp_offset:
      name: Auto Mode Temp Offset
    outdoor_temperature:
      name: Outdoor Temperature # Available only when device is active
text_sensor:
    model_name:
number:
    auto_target_temperature_offset:
Hi @RD2
Given the provided error messages, it looks like you have a UART misconfiguration. In the logs, you can see outgoing serial requests from the ESP32 board itself appearing as incoming RX messages from the AC unit (MT 0000 FFFF is sent to the AC unit from the ESP32). These obviously cannot be parsed as incoming messages.
Please double-check the correctness of your UART pins and hardware connections, make sure you did not short circuit RX/TX.
@RD2
Also, from this picture, it looks like you are missing 3.3V and GND connections that should go from the ESP board to the LV and GND lines on the TTL converter.
Thanks a lot ! I have check at least 10 times Rx and Tx wires, but forgot these 3.3V and GND wires :frowning:
So, I can confirm that it is working with RAK-18RPE unit, and I need to check with RAF-50RXE.
Thanks again for this project !
It’s also working with RAF-50RXE. I need to build 6 devices :slight_smile:
@RD2
Glad it works!
Don’t forget to rotate the passwords and secret tokens that you shared in the esphome config above :wink:
Yes I will do that !
Another thing, I have a HITACHI Thermodynamic Water Heater (HITACHI RAW35NHB + HITACHI TAW270NHB); and I saw the same CN7 connector on the motherboard of the indoor unit :
Is someone has already try to add Thermodynamic Water Heater support to this esphome-hlink-ac project ?
@RD2
I really doubt this project would be compatible with the water heater. You can carefully check the protocol used here - making sure the signal levels, pinouts, etc. are the same. But it is so different from AC that I think it might use a completely different protocol under the hood.
Thanks, another question, is the room temperature and presence detector of the AC unit can be accessible from the h_link protocole, and therefore added to ESPHome / Home assistant ?
The AC room temperature sensor is simply the current temperature of the AC climate device, which is reported continuously.
Regarding the presence detector, I don’t have an H-Link AC unit with a motion detector sensor. You can investigate whether it’s available through H-Link by using these protocol reverse-engineering sensors. If a motion sensor is available, I can add it as a sensor.
To show my setup, ESP32S2 mini inside homemade 3D print PETG box :
6 units to drive !
Thanks for this! Worked perfectly with my RAS-25YHA5!
Thank you @lumixen and others. I was able to integrate my 8 AC units and replace the official hi-kumo gateways. I’m delighted.
Like @RD2 I also have an Hitachi Yutampo thermodynamic water heater, plugged into the same external heatpump unit. The internet documentation is sparse but it indicates h-link/uart connectivity on the CN7 connector: https://documentation.hitachiaircon.com/glb/en/controls/spx-wfa/download/R0000026261_JCH
I am very tempted to start hacking in that direction. I understand, though, that the protocol will most likely have differences with the AC protocol, and will require some additional reverse engineering.
