Hive Boost Button?
Hi
I have the Hive Integration in HA which works fine with the default card but the boost option seems to default to 0.5 degrees above current and for 30 minutes only.
I want to create a new button which boosts for 1 hour at 22 degrees but have no clue where to begin?
If you go to dev tools and actions, you can use Hive: Boost heating on
Once set up you can copy to a script or button.
This is yaml that needs pasting into a script or button:
action: hive.boost_heating_on
  time_period: "01:00:00"
  temperature: 22
Thanks, I am obviously doing something wrong here:
show_name: true
show_icon: true
type: button
tap_action:
  temperature: 22
This gives me an error, apologies I am very new to this.
Just need the data: section 2 spaces right
show_name: true
show_icon: true
type: button
tap_action:
    temperature: 22
Hmmm, I still get this error:
Visual editor not supported
  • The provided value for ‘tap_action.action’ is not supported by the visual editor. We support (one of "none","toggle","more-info","call-service","perform-action","url","navigate","assist") but received (“hive.boost_heating_on”).
  • Key ‘tap_action.data’ is not expected or not supported by the visual editor.
You can still edit your config using YAML.
Give this a try, change the climate entity to match yours
show_name: true
show_icon: true
type: button
tap_action:
  action: perform-action
  perform_action: hive.boost_heating_on
    entity_id: climate.alices_room
    temperature: 22
entity: climate.alices_room
Are you doing this in the UI or YAML ?
This is UI:
Ignore the AM on the time period, its a bug
This worked perfectly, thank you so much!
Excellent, can you mark the post as solved
