Hive integration: `boost_heating` removed
I’m getting a message in the logs that this function is going to be removed soon and to use boost_heating_on instead. When I use boost_ heating_on the boost does not stop after the set time which is why I had created my own script using boost_heating. Not sure how to report this - this is happening with the 3rd party Hive integration
I’ve done some more testing and appears to work correctly if used in a script but if used directly in an automation then the boost goes on but doesn’t stop after the set time. I’ll play around with it some more.
