Hive integration errors after upgrading to 2022.07.*
I’ll start by saying that all the Hive automation/scripts were working errorless before switching to 2022.07.* . If I roll back to 2022.06.* no more errors, same automation/scripts.
Home Assistant is running as a VM in a KVM environment no changes were made between releases.
Need to mention that if I manually run the automation or the scripts related I dont get the errors. Strange thing is that the automation and the scripts are working and doing their job.
Here is my automation:
alias: Heating Ground Floor
 platform: time_pattern
 seconds: /30
 service_template: >
  {% if is_state('input_boolean.gfctsns_windowleft','on') or
    is_state('input_boolean.gfctsns_windowright', 'on') or
    is_state('input_boolean.gfctsns_diningright', 'on') or
    is_state('input_boolean.gfctsns_gardendoor', 'on') or
    is_state('input_boolean.gfctsns_kitchenwindow', 'on') %}
  script.heat_groundfloor_kick_off
  {% else %}
  script.heat_groundfloor_kick_on
  {% endif %}
And the related scripts used:
heat_groundfloor_kick_on:
 alias: HeatGroundFloorOn
 sequence:
 - service: climate.set_hvac_mode
    hvac_mode: 'auto'
    entity_id:
     - climate.cloakroomvalve
     - climate.livingroomvalve
     - climate.kitchenvalve
heat_groundfloor_kick_off:
 alias: HeatGroundFloorOff
 sequence:
    hvac_mode: 'off'
    entity_id:
Below a sample of the errors:
2022-07-15 10:37:37 ERROR (MainThread) [homeassistant.components.script.heat_firstfloor_kick_off] HeatFirstFloorOff: Error executing script. Unexpected error for call_service at pos 1: 'NoneType' object has no attribute 'status'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 447, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 680, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1713, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1750, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 930, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 717, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/hive/__init__.py", line 122, in wrapper
await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hive/climate.py", line 120, in async_set_hvac_mode
await self.hive.heating.setMode(self.device, new_mode)
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/heating.py", line 306, in setMode
await self.session.getDevices(device["hiveID"])
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 418, in getDevices
api_resp_d = await self.api.getAll()
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/api/hive_async_api.py", line 147, in getAll
json_return.update({"original": resp.status})
AttributeError: 'NoneType' object has no attribute 'status'
And a different one but related:
Logger: homeassistant.core
Source: components/hive/climate.py:120
First occurred: 11:42:00 (1 occurrences)
Last logged: 11:42:00
Error executing service: <ServiceCall climate.set_hvac_mode (c:01G80Q5ZWHYX7F5ZF36C66SMJ9): hvac_mode=off, entity_id=['climate.cloakroomvalve', 'climate.livingroomvalve', 'climate.kitchenvalve']>
  File "/usr/src/homeassistant/homeassistant/core.py", line 1731, in catch_exceptions
    await coro_or_task
    await coro
    await result
Any help, hint, and/or guidance is very welcome, thank you in advance.
There was a change in the auth for Hive and fixed in 2022.6.6, you need to remove the integration, turn on 2FA in Hive app and re-add the integration, lots of posts on here about it
https://community.home-assistant.io/search?q=hive%20order:latest
thanks for the reply, did that, it was working fine after the last Hive patch was applied, I know about the 2FA issue, the errors started as soon as I updated from 2022.6.7 (was the last 2022.6.*) to 2022.7.1
Yesterday I deleted the Hive integration (hoping for an easy fix) and re-added it, but no joy.
I think is somehow related to the python3.10 upgrade in 2022.7.1 but I’m not sure. Hopefully, someone with better knowledge will see this and point me in the right direction.
Ah ok. I’m not sure then, all working fine in 2022.7.3 for me. Maybe add an issue on GitHub ?
