HIVE INTEGRATION - Failed to perform the action
Hi Everyone - I’m hoping someone can help me! I’m quire new to home assistant and spent the last 2 weeks-ish setting up Home Assistant and getting all my devices integrated. I was almost at the point of getting my dashboard the way I want it & then all my HIVE Devices stopped responding to actions. They all report back correctly, If I durn on a device with the HIVE app then Home assistant knows what has happened but all attempts to adjust the heating or switch on a light from Home Assistance report “Failed to preform the action (switch/turn_on unknown error”. When I first installed the HIVE integration everything worker perfectly and it did do for 10 days or so but then yesterday afternoon they all stopped working. I’ve deleted and re-installed the integration (both the official one and the one vis HACS) around 10 times and always get the same issue. Can anyone help me with this problem please? Thank in advance!
PS - I Feel this may have happened after an updater, but I was tinkering a lot with the dashboard and can’t be certain when they all stopped working
PPS - I’ve searched & searched for a resolution all over the internet but don’t seem to be able to find a thread with this issue. Apologies in advance if this has already been asked & answered.
There was a problem yesterday. (Amazingly) it’s been fixed and there is an update for the integration - you should be seeing this.
WOW - So I just got really unlucky! - i’ll check for updates now - Thank you so much for your reply!
Wow, funny I am in almost an identical scenario, thanks @gwatuk for replying.
Thanks @gwatuk for your reply, I’ve just added the new HACS version and its all OK again. Thank You again for your support with this!!!
Should say I didn’t fix it!
I’m just the messenger with the good news :rofl:
I had exact same issue using the default integration with my smart plugs. Switching to HACS version resolved issue, thanks!
