Hive integration failing
Hello!
I am trying to implement hive into my new HA instance (OdroidN2+) but it seems to be failing and I’m perplexed as to why.
I am aware that the US servers are going down but I am UK based so wouldn’t expect this to impact me?
(I am not software smart - so this is new territory to me, hence me struggles with this, Solar int etc)
I use the integration and insert my credentials (fine) then get an error in the logs instantly saying;
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 353, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/hive/__init__.py", line 89, in async_setup_entry
    devices = await hive.session.startSession(hive_config)
  File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 494, in startSession
    await self.getDevices("No_ID")
  File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 417, in getDevices
    await self.hiveRefreshTokens()
  File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 304, in hiveRefreshTokens
    result = await self.auth.refresh_token(
  File "/usr/local/lib/python3.10/site-packages/apyhiveapi/api/hive_auth_async.py", line 548, in refresh_token
    result = await self.loop.run_in_executor(
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 391, in _api_call
    return self._make_api_call(operation_name, kwargs)
  File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 691, in _make_api_call
    request_dict = self._convert_to_request_dict(
  File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 739, in _convert_to_request_dict
    request_dict = self._serializer.serialize_to_request(
  File "/usr/local/lib/python3.10/site-packages/botocore/validate.py", line 360, in serialize_to_request
    raise ParamValidationError(report=report.generate_report())
botocore.exceptions.ParamValidationError: Parameter validation failed:
Invalid type for parameter AuthParameters, value: ({'REFRESH_TOKEN': 'A VERYLONGTOKEN'},), type: <class 'tuple'>, valid types: <class 'dict'>
You need to update to latest version and enable 2FA in Hive app
I’m on the latest and have 2FA already :frowning:
Just retried and all working. Strange as 2FA was on when I originally tried it!
