I have the Hive integration installed but for some reason it won’t update values unless I do something to the device on the dashboard (switch the heating on for example).
The integration has picked up my Hive devices so seems to be able to connect to the account. But it never updates the temperatures or heating state automatically. So currently it says it’s heating even though I know it’s not (and the widget shows it last updated last week). If I then switch the heating on manually through the dashboard widget it will switch the heating on and update the temperature shown to the current value, but then won’t ever update again until I do the same through the dashboard.
Does anyone have any suggestions on things I can check or try to get this working?
Thanks,
David.
