Hi
I’m having issues getting Hive working after the latest update. I was running something like 2022.5.x (I’ve been away so could only update today). It’s been running fine until updating to the latest version. To try and fix the issue, I’ve deleted the Hive integration, now when trying to re-add, I get ‘An unknown error has occured’ after entering my 2FA code.
I’m running on a VM and have the following:
core-2022.6.5
Installation Type: Home Assistant OS
Host Operating System: Home Assistant OS 8.1
Supervisor Version: supervisor-2022.05.3
Agent Version: 1.2.1
Docker Version: 20.10.14
Here’s my log:
Logger: aiohttp.server
Source: components/hive/config_flow.py:108
First occurred: 5:05:48 pm (1 occurrences)
Last logged: 5:05:48 pm
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 220, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 205, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 109, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 260, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 335, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/hive/config_flow.py", line 93, in async_step_2fa
return await self.async_setup_hive_entry()
File "/usr/src/homeassistant/homeassistant/components/hive/config_flow.py", line 108, in async_setup_hive_entry
await self.hive_auth.device_registration("Home Assistant")
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py", line 460, in device_registration
await self.confirm_device(device_name)
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py", line 480, in confirm_device
result = await self.loop.run_in_executor(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/botocore/client.py", line 391, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.9/site-packages/botocore/client.py", line 705, in _make_api_call
http, parsed_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/botocore/client.py", line 725, in _make_request
return self._endpoint.make_request(operation_model, request_dict)
File "/usr/local/lib/python3.9/site-packages/botocore/endpoint.py", line 104, in make_request
return self._send_request(request_dict, operation_model)
File "/usr/local/lib/python3.9/site-packages/botocore/endpoint.py", line 134, in _send_request
request = self.create_request(request_dict, operation_model)
File "/usr/local/lib/python3.9/site-packages/botocore/endpoint.py", line 117, in create_request
self._event_emitter.emit(event_name, request=request,
File "/usr/local/lib/python3.9/site-packages/botocore/hooks.py", line 357, in emit
return self._emitter.emit(aliased_event_name, **kwargs)
File "/usr/local/lib/python3.9/site-packages/botocore/hooks.py", line 228, in emit
return self._emit(event_name, kwargs)
File "/usr/local/lib/python3.9/site-packages/botocore/hooks.py", line 211, in _emit
response = handler(**kwargs)
File "/usr/local/lib/python3.9/site-packages/botocore/signers.py", line 93, in handler
return self.sign(operation_name, request)
File "/usr/local/lib/python3.9/site-packages/botocore/signers.py", line 165, in sign
auth.add_auth(request)
File "/usr/local/lib/python3.9/site-packages/botocore/auth.py", line 378, in add_auth
raise NoCredentialsError()
botocore.exceptions.NoCredentialsError: Unable to locate credentials
Thanks for any help guys
