Hive SLR1c & SLT6 Not pairing up
Hi all
Can any one guide me right direction please?
I have Hive SLR1c & SLT6 and both gets detected by zigbee but Thermostat never finishes pairing stuck on searching
https://www.zigbee2mqtt.io/devices/SLT6.html
https://www.zigbee2mqtt.io/devices/SLR1c.html
I have one set of its bigger brother that paired fine but these little ones not having it
Im using cc2531 based usb stick flashed with latest Z stack
Any help i appreciate
Regards
Did you manage to get this working? I’m having exactly the same problem, but I only have a SLR1c & SLT6, so at the moment I’m going to have to go back to using the Hive Hub, unless of course there is a fix for this.
Thanks for any help
I too am having this issue, do you know if anyone has managed to get this working? Thanks
No luck here either, using SLR2c and SLT6 Mini thermostat.
Just to update, switched from ZHA to Zigbee2MQTT and got everything synced up, followed Can I integrate Hive Active Heating into HA without the Hive Hub? - #17 by HarvsG
Thanks, I saw the Z2M option but have been trying to avoid the painful migration from ZHA. I’m starting to wonder if it’s unavoidable. Thanks for coming back to me!
The problem I have it that I have never used ZHA, I’ve always been trying to get this working via Z2M, and get stuck at the pairing phase like the OP. I’ve gone through the thread you linked, and can’t see how/what they did different than the guide on Z2M.
Any chance you can detail exactly what you did to get yours to work in Z2M?
Nevermind, went through the actual post you linked and it worked. not sure how that was different to the original method on Z2M database, but whatever it is it works now.
Thanks, I have now got one zigbee network running and can finally ditch that hive hub!!!
