hi - thanks for the reply. i am using 2fa and it asked for the passcode on setup. i finally accessed the logs - maybe they can help?
Logger: homeassistant.components.climate
Source: components/hive/init.py:150
Integration: Climate (documentation, issues)
First occurred: 15:25:47 (1 occurrences)
Last logged: 15:25:47
Error while setting up hive platform for climate
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 281, in _async_setup_platform
await asyncio.shield(task)
File “/usr/src/homeassistant/homeassistant/components/hive/climate.py”, line 64, in async_setup_entry
entities.append(HiveClimateEntity(hive, dev))
File “/usr/src/homeassistant/homeassistant/components/hive/climate.py”, line 113, in init
super().init(hive_session, hive_device)
File “/usr/src/homeassistant/homeassistant/components/hive/init.py”, line 150, in init
model=self.device[“deviceData”][“model”],
KeyError: ‘model’
Logger: homeassistant.components.switch
Integration: Switch (documentation, issues)
First occurred: 15:25:48 (1 occurrences)
Last logged: 15:25:48
Error while setting up hive platform for switch
File “/usr/src/homeassistant/homeassistant/components/hive/switch.py”, line 43, in async_setup_entry
entities.append(HiveSwitch(hive, dev, description))
File “/usr/src/homeassistant/homeassistant/components/hive/switch.py”, line 52, in init
super().init(hive, hive_device)
KeyError: ‘model’
Logger: homeassistant.components.sensor
Source: components/hive/sensor.py:66
Integration: Sensor (documentation, issues)
First occurred: 15:25:47 (2 occurrences)
hive: Error on device update!
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 493, in _async_add_entity
await entity.async_device_update(warning=False)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 703, in async_device_update
await task
File “/usr/src/homeassistant/homeassistant/components/hive/sensor.py”, line 66, in async_update
self._attr_native_value = self.device[“status”][“state”]
KeyError: ‘status’
