This one only works with hlk-dio16 application I know this one.
how to connect hlk-dio16 modebus with homeassistant I am connect connect modbus with homeassistant but Canot control with output and read input need coil modbus configuration
# Example configuration.yaml entry for a TCP connection
modbus:
type: tcp
host: 192.168.1.5
port: 8080
switch:
platform: modbus
coils:
- name: Switch1
hub: hub1
slave: 1
coil: 13
- name: Switch2
slave: 2
coil: 14
registers:
- name: Register1
hub: hub1
slave: 1
register: 11
command_on: 1
command_off: 0
binary-sensor:
platform: modbus
registers:
- name: Sensor1
hub: hub1
slave: 1
register: 100
but connected to homeassistant Canot Read any things any idea
Hello it is now posiple to integrate the HLK DIO 16 or not? Or have one a idea for Control it via Modbus? I have 4 from that and in the momend works just with the app in standalone.
Thanks.
Good Morning. probably a stupid question, but how can I use the files in the HA now?
Not yet, this is just implemented in the protocol library so far.
any hope this topic
Sure, mostly I’m just finishing the reverse engineering and re-implementation of the TCP socket based control protocol commands. This is just somewhat time consuming due to the reference client code I’m reverse engineering being rather poorly written.
Dear All , i am Molly from Hi-Link .
We are the manufacturer of HLK-DIO16 .
Please tell me the questions, i will answer one by one .
How to connect hlk-dio16 with homeassistant
Please integrate with homeassistant
Please integrate with homeassistant hlk-dio16
Hello jameshilliard and Community, I hope you all had a good Chrismas.
Does anyone have any news regarding the integration.
hello molly this topic are possible
So far they haven’t replied. How’s the sand of things do we get the iteration for the HLK DIO16 or not? I can wait, but only if it’s worth it.
I thank everyone who makes an effort here. but 3 weeks no answer or only a sign that there could be an integration is too long for me so I will probably have to look for another server.
Any updates on integration? I plan to buy this relay.
Hello everyone. is there anyone else who works on the intergarden from HLK DIO 16? Can we expect it or not? If I know that someone is doing something and it is going ahead somehow, I am ready for anything, but not seeing an answer and no progress for so long is sad. I have 4 of them installed in my house and it’s true if I get a connection with that. if the integration doesn’t work, maybe you have an idea how to control them via the Modbus function?
Thank you in advance
