I try integrate the HLK-LD2410C with NODEMCU32 V 3
MY CODE.
esphome:
friendly_name: HLK-LD2410-B
esp8266:
board: esp01_1m
Enable logging
logger:
baud_rate: 0
wifi:
ssid: !secret wifi_ssid
Optional Manual IP
manual_ip:
static_ip: 192.168.1.137
gateway : 192.168.1.1
subnet: 255.255.255.0
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Hlk-Ld2410-B Fallback Hotspot”
password: “teste@123”
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
timeout: 150s
max_move_distance : 6m
max_still_distance: 0.75m
g0_move_threshold: 10
g0_still_threshold: 20
g1_move_threshold: 10
g1_still_threshold: 20
g2_move_threshold: 20
g2_still_threshold: 21
g3_move_threshold: 30
g3_still_threshold: 31
g4_move_threshold: 40
g4_still_threshold: 41
g5_move_threshold: 50
g5_still_threshold: 51
g6_move_threshold: 60
g6_still_threshold: 61
g7_move_threshold: 70
g7_still_threshold: 71
g8_move_threshold: 80
g8_still_threshold: 81
platform: ld2410
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
binary_sensor:
platform: ld2410
has_target:
has_moving_target:
has_still_target:
pinout
LD-Vcc → MCU-VIN
LD-GND->MCU-GND
LD-RX->MCU-TX
LD-TX->MCU-RX
But all sensors displayed unknown
Please i need HELP
zoogara
(Daryl)
June 13, 2023, 11:34am
2
Hi - Have a read of the linked topic - also paying attention to formatting your YAML using preformatted text tags:
Before we begin…
This forum is not a helpdesk
The people here don’t work for Home Assistant, that’s an open source project. We are volunteering our free time to help others. Not all topics may get an answer, never mind one that helps you solve your problem.
[image]
This also isn’t a general home automation forum, this is a forum for Home Assistant and things related to it. Any question about Home Assistant, and about using things with Home Assistant, is welcome here. We can’t help you with e…
Edit your post using the correct tags and someone may be able to help.
alfwro13
(Andre W.)
July 11, 2023, 2:53pm
3
Try TX-TX and RX-RX and it should work just fine.
Hello, This is Annie from Hi-Link. I consulted our technicist and got the solution as follows. You could try to power HLK-2410C alone and try RX-RX, TX-TX and Gnd-Gnd.
Bohica93
(Dalan)
September 28, 2023, 2:15pm
5
I am having the same issue. Below is my YAML code
esphome:
friendly_name: PlayRoom PS1
esp8266:
board: esp01_1m
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "NO4/pwirUW0rkhe3syv/iEgLTugbjoGejrFxRuqzwMc="
ota:
password: "43ffbe08b7e117093fc72704698cc71c"
wifi:
ap:
ssid: "Playroom-Ps1 Fallback Hotspot"
password: "CdioIm9PbgAw"
captive_portal:
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
out_pin_presence_status:
name: out pin presence status
- platform: ld2410
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0:
move_energy:
name: g0 move energy
still_energy:
name: g0 still energy
g1:
move_energy:
name: g1 move energy
still_energy:
name: g1 still energy
g2:
move_energy:
name: g2 move energy
still_energy:
name: g2 still energy
g3:
move_energy:
name: g3 move energy
still_energy:
name: g3 still energy
g4:
move_energy:
name: g4 move energy
still_energy:
name: g4 still energy
g5:
move_energy:
name: g5 move energy
still_energy:
name: g5 still energy
g6:
move_energy:
name: g6 move energy
still_energy:
name: g6 still energy
g7:
move_energy:
name: g7 move energy
still_energy:
name: g7 still energy
g8:
move_energy:
name: g8 move energy
still_energy:
name: g8 still energy
switch:
- platform: ld2410
engineering_mode:
bluetooth:
name: "control bluetooth"
number:
- platform: ld2410
timeout:
light_threshold:
name: light threshold
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
button:
- platform: ld2410
factory_reset:
restart:
query_params:
text_sensor:
- platform: ld2410
version:
mac_address:
I have it working on an esp32dev board, but can’t get it working on nodemcu32-v-3
Any help would be appreciated - Thanks
Has anyone solved this issue?
Thank you!
adnancu
(Adnan)
August 23, 2024, 8:03pm
7
yes i am reslove the issue i change tx and rx pin position in file and work fine for me… im using d32 wemos
