HLK-LD2450 Initial experiments to connect to HomeAssistant
Very nice work, this should be the first HA map card based on the LD2450!
We have it now!
Could never upgrade the radar on the ios app for some reason, had to use the android app for that
The target position map can also be flipped around so that it appears with the LD2450 on top (similar to the image from the HiLink PC app) by switching the range numbers around for the axis like below and the target size can be increased by changing the marker size value. This makes the visualisation of the position easier.
layout:
  xaxis:
    type: number
    fixedrange: true
    range:
      - 4000
      - -4000
  yaxis:
    fixedrange: true
    range:
      - 6000
      - 0
Yes, it could be also be added the angle +/- 60degrees of the ld2450 range with another 2 segments by defining another entity similar with the zone ones. It may help in positioning the sensor.
Hey folks. I’ve designed another case for the LD2410C and an ESP32 C3 Mini. Source and model files are on Printables:
https://www.printables.com/model/582630-case-for-esp32-c3-super-mini-and-ld2410c
I’ve previously posted one for use with the ESP32 S2 Mini, but can’t recall if I posted it here or not:
https://www.printables.com/model/541368-case-for-esp32-s2-mini-and-ld2410c
Thanks for the idea. I’ve given that a go and the following coverage angle seems to fit my target detection area when I walk around the room.
  - entity: ''
    mode: lines
    line:
      shape: line
      width: 1
      dash: dot
    x:
      - 4000
      - 0
      - -4000
    'y':
      - 2000
      - 0
      - 2000
I think the ymax is x/tan(60). It should be arround ymax=2312. May be we can calculate parametric based on range values and tan(60)=x/y.
I’ve added the calculation for the coverage angle and also for the 6m range of the sensor:
Here is the full YAML for the Plotly Graph card that I have put together:
type: custom:plotly-graph
title: Target Positions
refresh_interval: 1
hours_to_show: current_day
layout:
  showlegend: true
  margin:
    l: 50
    r: 20
    t: 20
    b: 40
  autosize: false
  height: 300
  xaxis:
    type: number
    fixedrange: true
    range:
      - 4000
      - -4000
  yaxis:
    fixedrange: true
    range:
      - 6000
      - 0
entities:
  - entity: ''
    marker:
    line:
      shape: spline
      width: 5
    x:
      - $ex hass.states["sensor.screek_human_sensor_2a_734e6c_target1_x"].state
    'y':
      - $ex hass.states["sensor.screek_human_sensor_2a_734e6c_target1_y"].state
  - entity: ''
    marker:
    line:
      shape: spline
      width: 5
    x:
      - $ex hass.states["sensor.screek_human_sensor_2a_734e6c_target2_x"].state
    'y':
      - $ex hass.states["sensor.screek_human_sensor_2a_734e6c_target2_y"].state
  - entity: ''
    marker:
    line:
      shape: spline
      width: 5
    x:
      - $ex hass.states["sensor.screek_human_sensor_2a_734e6c_target3_x"].state
    'y':
      - $ex hass.states["sensor.screek_human_sensor_2a_734e6c_target3_y"].state
  - entity: ''
    mode: lines
    line:
      shape: line
      width: 2
    x:
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone1_x_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone1_x_end"].state
    'y':
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone1_y_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone1_y_end"].state
  - entity: ''
    mode: lines
    line:
      shape: line
      width: 2
    x:
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone2_x_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone2_x_end"].state
    'y':
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone2_y_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone2_y_end"].state
  - entity: ''
    mode: lines
    line:
      shape: line
      width: 2
    x:
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone3_x_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone3_x_end"].state
    'y':
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone3_y_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zone3_y_end"].state
  - entity: ''
    mode: lines
    line:
      shape: line
      width: 2
    x:
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zout1_x_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zout1_x_end"].state
    'y':
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zout1_y_begin"].state
      - $ex hass.states["number.screek_human_sensor_2a_734e6c_zout1_y_end"].state
  - entity: ''
    mode: lines
    fill: tonexty
    fillcolor: rgba(168, 216, 234, 0.15)
    line:
      shape: line
      width: 1
      dash: dot
    x:
      - 0
      - $ex 6000 * Math.sin((2 * Math.PI)/360 * 60)
      - 4000
      - 3000
      - 2000
      - 1000
      - 0
      - -1000
      - -2000
      - -3000
      - -4000
      - $ex -6000 * Math.sin((2 * Math.PI)/360 * 60)
      - 0
    'y':
      - 0
      - $ex 6000 * Math.cos((2 * Math.PI)/360 * 60)
      - $ex Math.sqrt( 6000**2 - 4000**2 )
      - $ex Math.sqrt( 6000**2 - 3000**2 )
      - $ex Math.sqrt( 6000**2 - 2000**2 )
      - $ex Math.sqrt( 6000**2 - 1000**2 )
      - 6000
      - 0
raw_plotly_config: true
Things are getting interesting, great job, athua.
The only problem it seems to have now is that it looks like they’re a little too sketchy in some places, maybe the lines of that zone could be made dashed as well to make them very light, or differentiate their backgrounds with a subtle color.
The solid lines, which look a bit puzzling, take up the entire field of view.
Can you include a screenshot so I can see what it looks like for you?
As you can see from the screenshot in my post above, it all appears ok for me.
I’ve changed the Zones to be shaded and made the lines thinner so it should be clearer and less cluttered now. Also with the Plotly graph, you can click on the Legend items to hide them if you only want to look at a specific items. It is also very customisable and is easy to change the colours and line thickness to meet individual needs.
LD2450-Target-Positions4
refresh_interval: 1
layout:
  height: 230
  margin:
    l: 50
    r: 20
    t: 20
    b: 40
  showlegend: true
  xaxis:
    dtick: 1000
    gridcolor: RGBA(200,200,200,0.15)
    zerolinecolor: RGBA(200,200,200,0.15)
    type: number
    fixedrange: true
    range:
      - 4000
      - -4000
  yaxis:
    dtick: 1000
    scaleanchor: x
    scaleratio: 1
    fixedrange: true
    range:
      - 6000
      - 0
entities:
  - entity: ''
    marker:
    line:
      shape: spline
      width: 5
    x:
    'y':
  - entity: ''
    marker:
    line:
      shape: spline
      width: 5
    x:
    'y':
  - entity: ''
    marker:
    line:
      shape: spline
      width: 5
    x:
    'y':
  - entity: ''
    mode: lines
    fill: toself
    fillcolor: RGBA(20,200,0,0.06)
    line:
      color: RGBA(20,200,0,0.2)
      shape: line
      width: 2
    x:
        $ex
        $ex
        $ex
        $ex
        $ex
    'y':
        $ex
        $ex
        $ex
        $ex
        $ex
  - entity: ''
    mode: lines
    fill: toself
    fillcolor: RGBA(200,0,255,0.06)
    line:
      color: RGBA(200,0,255,0.2)
      shape: line
      width: 2
    x:
        $ex
        $ex
        $ex
        $ex
        $ex
    'y':
        $ex
        $ex
        $ex
        $ex
        $ex
  - entity: ''
    mode: lines
    fill: toself
    fillcolor: RGBA(200,120,55,0.06)
    line:
      color: RGBA(200,120,55,0.2)
      shape: line
      width: 2
    x:
        $ex
        $ex
        $ex
        $ex
        $ex
    'y':
        $ex
        $ex
        $ex
        $ex
        $ex
  - entity: ''
    mode: lines
    fill: toself
    fillcolor: RGBA(255,0,0,0.15)
    line:
      shape: line
      width: 1
      color: RGBA(255,0,0,0.2)
    x:
        $ex
        $ex
        $ex
        $ex
        $ex
    'y':
        $ex
        $ex
        $ex
        $ex
        $ex
  - entity: ''
    mode: lines
    fill: tonexty
    line:
      shape: line
      width: 1
      dash: dot
    x:
      - 0
      - 4500
      - 4000
      - 3000
      - 2000
      - 1000
      - 0
      - -1000
      - -2000
      - -3000
      - -4000
      - -4500
      - 0
    'y':
      - 0
      - $ex Math.sqrt( 6000**2 - 4500**2 )
      - 6000
      - 0
If you use the above config without the layout height set on a Dashboard Panel (1 card), you get to see the whole coverage area map:
This looks so cool, athua!
Nice work!
This is an awesome map system!
What are your UART settings for this combination (ESP32-C3 “Super Mini” and LD2410C). I just can’t get it to work. :confused:
Here’s the full config:
substitutions:
  # Set the device name
  # Set the friendly name
  friendly_name: friendly
  # Provide the wifi SSID
  wifi: !secret wifi_ssid
  #Provide the wifi password
  wifi_pass: !secret wifi_password
### No modifications needed below here ###
esphome:
  friendly_name: $friendly_name
  platformio_options:
    board_build.flash_mode: dio
    board_build.f_cpu: 80000000L
  name_add_mac_suffix: false
wifi:
  ssid: $wifi
  password: $wifi_pass
  power_save_mode: LIGHT
  ap:
  output_power: 15db
captive_portal:
web_server:
  port: 80
esp32:
  board: lolin_c3_mini
  framework:
    type: esp-idf
api:
ota:
logger:
  level: DEBUG
uart:
  tx_pin: GPIO4
  rx_pin: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
    out_pin_presence_status:
      name: Out Pin Presence Status
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
  - platform: internal_temperature
    name: ESP Temperature
    unit_of_measurement: °C
    device_class: TEMPERATURE
    update_interval: 30s
    entity_category: "diagnostic"
  - platform: uptime
    update_interval: 10s
  - platform: wifi_signal
switch:
  - platform: ld2410
    engineering_mode:
      name: "LD2410 Engineering Mode"
    bluetooth:
      name: "LD2410 bluetooth"
number:
  - platform: ld2410
    timeout:
    light_threshold:
      name: Light Threshold
    max_move_distance_gate:
      name: Max Move Distance Gate
    max_still_distance_gate:
      name: Max Still Distance Gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
button:
  - platform: ld2410
    factory_reset:
      name: "LD2410 Factory Reset"
    restart:
    query_params:
      name: "LD2410 Query Params"
  - platform: restart
    icon: mdi:power-cycle
text_sensor:
  - platform: ld2410
    version:
      name: "LD2410 Firmware Version"
    mac_address:
      name: "LD2410 MAC Address"
select:
  - platform: ld2410
    distance_resolution:
      name: "Distance Resolution"
    baud_rate:
    light_function:
    out_pin_level:
      name: Out Pin Level
light:
  - platform: status_led
    pin:
      number: GPIO8
      inverted: True
    internal: True
    restore_mode: ALWAYS_OFF
Alternatively, you can just use this bit, which imports the rest of the config from Github.
Just replace the items under substitutions.
This “packages” is pulling in the rest of the configs from here:
great, thank you very much
i removed layout: height but it still doesn’t display fully
I totally missed that I posted this in the wrong thread. Whoopsies.
Are you using a Dashboard with a View Type of Panel (1 card) and tried in landscape mode? The screenshot above that shows the full area is from a PC and not a phone.
If you want to view on the phone, you will need to adjust the height value.
Experiment with the value and see what you get.
Alternatively, leave the height value there but change the X-axis range from 4000 to -4000 to 6000 to -6000 which should widen the chart.
There is no one size fits all due to the many different layouts and devices that can be used.
Hi, just updated to latest esphome addon and I’m getting a bunch of errors with the default yaml (component not found)
Any way to fix this?
@athua The Plotly graph is amazing! Thank you so much.
Just one thing - if your HA instance is set up for Imperial units like we are in the USA the positions all get converted to inches, so to make the graphs work right you have to multiply the target position x/y data by 25.4.
Confusingly, of course, all of the settings remain in mm.
Not sure if there is any good way to automate the adjustments or if this is something us backwards folks in the USA will just have to fix manually and live with.
In any case - THANK YOU for taking the time to put this together and publish it.
Thanks. It took lots of experimenting with different graphing tools before settling on Plotly which supported what I wanted by allowing a custom X-axis that was not time based.
As the data from the sensors are returning metric, maybe you could try creating template sensors to convert each of the metric sensors and then use those for the graph.
Maybe something like this:
template:
  - sensor:
      - name: "Target1_x_inches"
        state: |
          {{(states('sensor.target1_x_presence_radar')|float / 25.4) | round(2)}}
        unit_of_measurement: "in"
        state_class: "measurement"
Or do I have it around the wrong way around and the sensors are returning the values in imperial units but the graph is in metric? If its the graph, you could try chaging the axis limits from 6000 to 236.22 (6000/25.4) which should hopefully graph the points in inches rather than mm.
