Can you post the actual errors that you received when compiling the upgrade?
I just upgraded my LD2450 unit with a Wemos D1 Mini ESP32 compatible board to ESPHome 2023.9.1 with no issues. It upgraded and compiled with no errors.
I do have ‘improv_serial:’ commented out in my YAML.
I’ve removed the ‘improv_serial:’ line but I’m still getting the same error on several lines.
Do you mind taking a look at my config?
I have only upgraded my LD2450 built with a Wemos D1 Mini ESP32 board, I have only used parts of the config from the Screek 2A YAML. For my Screek 2A, it is currently using the Screek firmware and not the ESPHome YAML config.
In particular, I have not used the following and when I try including it, I get errors with the logger component. Maybe you can try excluding it and see if it compiles.
external_components:
- source:
type: git
url: https://github.com/screekworkshop/custom_components_support_for_screek_2a
ref: main
components: [esp32, uart]
If that doesn’t work then we will have to wait for someone from Screek Workshop to take a look at it.
This is just odd, no difference even with the external_components line removed
I think I need to roll back to the previous esphome addon.
Anyway to do that?
Here is my YAML config. Maybe you could try taking parts from it.
I have included some extra bits as I am experimenting with trying to control the on-board LED on my ESP32 board.
substitutions:
friendly_name: "Presence Radar"
espID: "esp32_presence_radar"
esphome:
on_boot:
- priority: 2000
then:
lambda: |-
id(zone1_target_exsits).publish_state(false);
id(zone2_target_exsits).publish_state(false);
id(zone3_target_exsits).publish_state(false);
id(zone_ex1_target_exsits).publish_state(false);
#debug:
# update_interval: 30s
api:
ota:
#improv_serial:
globals:
- id: last_update_ld2450
type: unsigned long
restore_value: no
initial_value: '0'
- id: init_zone_publish
type: bool
restore_value: no
initial_value: "false"
logger:
level: INFO
# level: DEBUG
# level: VERBOSE
baud_rate: 0
esp32:
board: wemos_d1_mini32
#board: esp32dev
framework:
type: arduino
wifi:
networks:
- ssid: !secret wifi_ssid
priority: 2
- ssid: !secret wifi2_ssid
password: !secret wifi2_password
priority: 1
output_power: 10dB
output:
- platform: ledc
pin:
number: GPIO2
inverted: false
light:
- platform: monochromatic
name: "ESP LED ${friendly_name}"
output: onboard_led
effects:
- pulse:
- platform: binary
name: "ESP Binary LED ${friendly_name}"
output: onboard_led
script:
- id: check_zone1_vaild
then:
- lambda: |-
if (id(zone1_x_begin).state > id(zone1_x_end).state){
id(tips_zone1_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone1_y_begin).state > id(zone1_y_end).state){
id(tips_zone1_conf).publish_state("Err: Y-Begin > Y-End");
return;
if (id(zone1_x_begin).state == 0, id(zone1_x_end).state == 0, id(zone1_y_begin).state == 0, id(zone1_y_end).state == 0){
id(tips_zone1_conf).publish_state("Configure below");
return;
int x_size = id(zone1_x_end).state - id(zone1_x_begin).state;
int y_size = id(zone1_y_end).state - id(zone1_y_begin).state;
char combined[80];
sprintf(combined, "Curr Size: %d x %d", x_size, y_size);
id(tips_zone1_conf).publish_state(combined);
- id: check_zone2_vaild
then:
- lambda: |-
if (id(zone2_x_begin).state > id(zone2_x_end).state){
id(tips_zone2_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone2_y_begin).state > id(zone2_y_end).state){
id(tips_zone2_conf).publish_state("Err: Y-Begin > Y-End");
return;
if (id(zone2_x_begin).state == 0, id(zone2_x_end).state == 0, id(zone2_y_begin).state == 0, id(zone2_y_end).state == 0){
id(tips_zone2_conf).publish_state("Configure below");
return;
int x_size = id(zone2_x_end).state - id(zone2_x_begin).state;
int y_size = id(zone2_y_end).state - id(zone2_y_begin).state;
char combined[80];
id(tips_zone2_conf).publish_state(combined);
- id: check_zone3_vaild
then:
- lambda: |-
if (id(zone3_x_begin).state > id(zone3_x_end).state){
id(tips_zone3_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone3_y_begin).state > id(zone3_y_end).state){
id(tips_zone3_conf).publish_state("Err: Y-Begin > Y-End");
return;
if (id(zone3_x_begin).state == 0, id(zone3_x_end).state == 0, id(zone3_y_begin).state == 0, id(zone3_y_end).state == 0){
id(tips_zone3_conf).publish_state("Configure below");
return;
int x_size = id(zone3_x_end).state - id(zone3_x_begin).state;
int y_size = id(zone3_y_end).state - id(zone3_y_begin).state;
char combined[80];
id(tips_zone3_conf).publish_state(combined);
- id: check_zout1_vaild
then:
- lambda: |-
if (id(zone_ex1_x_begin).state > id(zone_ex1_x_end).state){
id(tips_zone_ex1_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone_ex1_y_begin).state > id(zone_ex1_y_end).state){
id(tips_zone_ex1_conf).publish_state("Err: Y-Begin > Y-End");
return;
id(tips_zone_ex1_conf).publish_state("Zone Exclusion 1");
button:
- platform: restart
name: "ESP32 Restart ${friendly_name}"
- platform: safe_mode
name: "ESP32 Safe Mode Boot ${friendly_name}"
entity_category: diagnostic
switch:
name: "Pulse LED ${friendly_name}"
optimistic: True
turn_on_action:
- light.turn_on:
effect: pulse
turn_off_action:
- light.turn_off:
name: "Presence LED ${friendly_name}"
optimistic: True
name: "Zout1 Enable ${friendly_name}"
optimistic: True
icon: mdi:account-cancel
entity_category: config
restore_mode: RESTORE_DEFAULT_OFF
text_sensor:
- platform: wifi_info
ip_address:
name: "ESP IP Address ${friendly_name}"
ssid:
name: "ESP Connected SSID ${friendly_name}"
bssid:
name: "ESP Connected BSSID ${friendly_name}"
mac_address:
name: "ESP Mac Wifi Address ${friendly_name}"
scan_results:
name: "ESP Latest Scan Results ${friendly_name}"
name: "Zone1 Info ${friendly_name}"
icon: mdi:information-outline
lambda: |-
return {"Configure below" };
update_interval: 1000s
name: "Zone2 Info ${friendly_name}"
lambda: |-
name: "Zone3 Info ${friendly_name}"
lambda: |-
name: "Zout1 Info ${friendly_name}"
lambda: |-
return {"Zone Exclusion 1" };
binary_sensor:
- platform: status
name: "ESP Status ${friendly_name}"
name: "Any Presence ${friendly_name}"
device_class: occupancy
filters:
- delayed_off: !lambda |-
if (!id(init_zone_publish)) {
return 0;
return id(any_presence_timeout).state * 1000.0;
on_press:
then:
- if:
condition:
switch.is_on: presenceLED
then:
- light.turn_on: led
on_release:
then:
- if:
condition:
then:
- light.turn_off: led
name: "Zone1 Presence ${friendly_name}"
filters:
return 0;
return id(zone1_x_timeout).state * 1000.0;
name: "Zone2 Presence ${friendly_name}"
filters:
return 0;
return id(zone2_x_timeout).state * 1000.0;
name: "Zone3 Presence ${friendly_name}"
filters:
return 0;
return id(zone3_x_timeout).state * 1000.0;
name: "Zout1 Presence ${friendly_name}"
icon: mdi:account-multiple-remove
- platform: internal_temperature
name: "ESP Temperature ${friendly_name}"
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB ${friendly_name}"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent ${friendly_name}"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
- platform: uptime
name: "ESP Uptime ${friendly_name}"
name: "All Target Counts ${friendly_name}"
accuracy_decimals: 0
icon: "mdi:counter"
unit_of_measurement: "targets"
name: "Zone1 Target Counts ${friendly_name}"
icon: "mdi:counter"
name: "Zone2 Target Counts ${friendly_name}"
icon: "mdi:counter"
name: "Zone3 Target Counts ${friendly_name}"
icon: "mdi:counter"
name: "Zout1 Target Counts ${friendly_name}"
icon: mdi:account-multiple-minus-outline
name: "Target1 X ${friendly_name}"
unit_of_measurement: 'mm'
state_class: measurement
device_class: distance
name: "Target1 Y ${friendly_name}"
name: "Target1 Speed ${friendly_name}"
accuracy_decimals: 2
unit_of_measurement: 'm/s'
device_class: speed
name: "Target1 Resolution ${friendly_name}"
name: "Target2 X ${friendly_name}"
# update_interval: 1s
name: "Target2 Y ${friendly_name}"
name: "Target2 Speed ${friendly_name}"
device_class: speed
name: "Target2 Resolution ${friendly_name}"
name: "Target3 X ${friendly_name}"
name: "Target3 Y ${friendly_name}"
name: "Target3 Speed ${friendly_name}"
device_class: speed
name: "Target3 Resolution ${friendly_name}"
number:
name: "Any Presence Timeout ${friendly_name}"
min_value: 0
max_value: 600
mode: box
device_class: duration
unit_of_measurement: s
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
name: "Zone1 Timeout ${friendly_name}"
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
name: "Zone1 X-Begin ${friendly_name}"
min_value: -4000
max_value: 4000
mode: box
unit_of_measurement: mm
icon: mdi:arrow-left-bold
step: 10
optimistic: True
initial_value: 0
restore_value: True
name: "Zone1 X-End ${friendly_name}"
mode: box
min_value: -4000
max_value: 4000
icon: mdi:arrow-right-bold
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zone1 Y-Begin ${friendly_name}"
mode: box
min_value: 0
max_value: 6000
icon: mdi:arrow-up-bold
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zone1 Y-End ${friendly_name}"
icon: mdi:arrow-down-bold
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
name: "Zone2 Timeout ${friendly_name}"
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
name: "Zone2 X-Begin ${friendly_name}"
min_value: -4000
max_value: 4000
mode: box
step: 10
optimistic: True
initial_value: 0
restore_value: True
name: "Zone2 X-End ${friendly_name}"
mode: box
min_value: -4000
max_value: 4000
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zone2 Y-Begin ${friendly_name}"
mode: box
min_value: 0
max_value: 6000
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zone2 Y-End ${friendly_name}"
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
name: "Zone3 Timeout ${friendly_name}"
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
name: "Zone3 X-Begin ${friendly_name}"
min_value: -4000
max_value: 4000
mode: box
step: 10
optimistic: True
initial_value: 0
restore_value: True
name: "Zone3 X-End ${friendly_name}"
mode: box
min_value: -4000
max_value: 4000
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zone3 Y-Begin ${friendly_name}"
mode: box
min_value: 0
max_value: 6000
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zone3 Y-End ${friendly_name}"
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
name: "Zout1 X-Begin ${friendly_name}"
min_value: -4000
max_value: 4000
mode: box
step: 10
optimistic: True
initial_value: 0
restore_value: True
name: "Zout1 X-End ${friendly_name}"
mode: box
min_value: -4000
max_value: 4000
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zout1 Y-Begin ${friendly_name}"
mode: box
min_value: 0
max_value: 6000
step: 10
initial_value: 0
optimistic: True
restore_value: True
name: "Zout1 Y-End ${friendly_name}"
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
uart:
tx_pin:
number: GPIO17
mode:
pullup: true
rx_pin:
number: GPIO16
mode:
pullup: true
baud_rate: 256000
parity: NONE
stop_bits: 1
debug:
direction: BOTH
dummy_receiver: True
after:
delimiter: [0X55, 0XCC]
sequence:
- lambda: |-
if ((millis() - id(last_update_ld2450)) <= 500) {
return;
id(last_update_ld2450) = millis();
// p1
int16_t p1_x = (uint16_t((bytes[5] << 8) | bytes[4] ));
if ((bytes[5] & 0x80) >> 7){
p1_x -= pow(2, 15);
}else{
p1_x = 0 - p1_x;
int16_t p1_y = (uint16_t((bytes[7] << 8) | bytes[6] ));
if ((bytes[7] & 0x80) >> 7){
p1_y -= pow(2, 15);
}else{
p1_y = 0 - p1_y;
int p1_speed = (bytes[9] << 8 | bytes[8] );
if ((bytes[9] & 0x80) >> 7){
p1_speed -= pow(2, 15);
}else{
p1_speed = 0 - p1_speed;
int16_t p1_distance_resolution = (uint16_t((bytes[11] << 8) | bytes[10] ));
// p2
int16_t p2_x = (uint16_t((bytes[13] << 8) | bytes[12] ));
if ((bytes[13] & 0x80) >> 7){
p2_x -= pow(2, 15);
}else{
p2_x = 0 - p2_x;
int16_t p2_y = (uint16_t((bytes[15] << 8) | bytes[14] ));
if ((bytes[15] & 0x80) >> 7){
p2_y -= pow(2, 15);
}else{
p2_y = 0 - p2_y;
int p2_speed = (bytes[17] << 8 | bytes[16] );
if ((bytes[17] & 0x80) >> 7){
p2_speed -= pow(2, 15);
}else{
p2_speed = 0 - p2_speed;
int16_t p2_distance_resolution = (uint16_t((bytes[19] << 8) | bytes[18] ));
// p3
int16_t p3_x = (uint16_t((bytes[21] << 8) | bytes[20] ));
if ((bytes[21] & 0x80) >> 7){
p3_x -= pow(2, 15);
}else{
p3_x = 0 - p3_x;
int16_t p3_y = (uint16_t((bytes[23] << 8) | bytes[22] ));
if ((bytes[23] & 0x80) >> 7){
p3_y -= pow(2, 15);
}else{
p3_y = 0 - p3_y;
int p3_speed = (bytes[25] << 8 | bytes[24] );
if ((bytes[25] & 0x80) >> 7){
p3_speed -= pow(2, 15);
}else{
p3_speed = 0 - p3_speed;
int16_t p3_distance_resolution = (uint16_t((bytes[27] << 8) | bytes[26] ));
bool p1_vaild = (p1_x != 0 || p1_y > 0);
bool p2_vaild = (p2_x != 0 || p2_y > 0);
bool p3_vaild = (p3_x != 0 || p3_y > 0);
// zone exlude 1
int16_t target_count_in_zone_ex1 = 0;
int16_t zone_ex1_x_min = id(zone_ex1_x_begin).state;
int16_t zone_ex1_x_max = id(zone_ex1_x_end).state;
int16_t zone_ex1_y_min = id(zone_ex1_y_begin).state;
int16_t zone_ex1_y_max = id(zone_ex1_y_end).state;
bool p1_zone_ex_enter = false;
bool p2_zone_ex_enter = false;
bool p3_zone_ex_enter = false;
if (id(zone_ex1_enable).state){
if (p1_vaild){
if (p1_x >= zone_ex1_x_min && p1_x <= zone_ex1_x_max && p1_y >= zone_ex1_y_min && p1_y <= zone_ex1_y_max){
p1_zone_ex_enter = true;
target_count_in_zone_ex1 ++;
if (p2_vaild){
if (p2_x >= zone_ex1_x_min && p2_x <= zone_ex1_x_max && p2_y >= zone_ex1_y_min && p2_y <= zone_ex1_y_max){
p2_zone_ex_enter = true;
if (p3_vaild){
if (p3_x >= zone_ex1_x_min && p3_x <= zone_ex1_x_max && p3_y >= zone_ex1_y_min && p3_y <= zone_ex1_y_max){
p3_zone_ex_enter = true;
bool has_target_in_zone_ex1 = (target_count_in_zone_ex1 > 0);
int16_t all_target_counts = 0;
if (p1_vaild && !p1_zone_ex_enter){
all_target_counts ++;
if (p2_vaild && !p2_zone_ex_enter){
if (p3_vaild && !p3_zone_ex_enter){
bool has_target_in_zone_all = (all_target_counts > 0);
// zone 1 check
int16_t target_count_in_zone1 = 0;
int16_t zone1_x_min = id(zone1_x_begin).state;
int16_t zone1_x_max = id(zone1_x_end).state;
int16_t zone1_y_min = id(zone1_y_begin).state;
int16_t zone1_y_max = id(zone1_y_end).state;
if (p1_x >= zone1_x_min && p1_x <= zone1_x_max && p1_y >= zone1_y_min && p1_y <= zone1_y_max){
target_count_in_zone1 ++;
if (p2_x >= zone1_x_min && p2_x <= zone1_x_max && p2_y >= zone1_y_min && p2_y <= zone1_y_max){
if (p3_x >= zone1_x_min && p3_x <= zone1_x_max && p3_y >= zone1_y_min && p3_y <= zone1_y_max){
bool has_target_in_zone1 = (target_count_in_zone1 > 0);
// zone 2 check
int16_t target_count_in_zone2 = 0;
int16_t zone2_x_min = id(zone2_x_begin).state;
int16_t zone2_x_max = id(zone2_x_end).state;
int16_t zone2_y_min = id(zone2_y_begin).state;
int16_t zone2_y_max = id(zone2_y_end).state;
if (p1_x >= zone2_x_min && p1_x <= zone2_x_max && p1_y >= zone2_y_min && p1_y <= zone2_y_max){
target_count_in_zone2 ++;
if (p2_x >= zone2_x_min && p2_x <= zone2_x_max && p2_y >= zone2_y_min && p2_y <= zone2_y_max){
if (p3_x >= zone2_x_min && p3_x <= zone2_x_max && p3_y >= zone2_y_min && p3_y <= zone2_y_max){
bool has_target_in_zone2 = (target_count_in_zone2 > 0);
// zone 3 check
int16_t target_count_in_zone3 = 0;
int16_t zone3_x_min = id(zone3_x_begin).state;
int16_t zone3_x_max = id(zone3_x_end).state;
int16_t zone3_y_min = id(zone3_y_begin).state;
int16_t zone3_y_max = id(zone3_y_end).state;
if (p1_x >= zone3_x_min && p1_x <= zone3_x_max && p1_y >= zone3_y_min && p1_y <= zone3_y_max){
target_count_in_zone3 ++;
if (p2_x >= zone3_x_min && p2_x <= zone3_x_max && p2_y >= zone3_y_min && p2_y <= zone3_y_max){
if (p3_x >= zone3_x_min && p3_x <= zone3_x_max && p3_y >= zone3_y_min && p3_y <= zone3_y_max){
bool has_target_in_zone3 = (target_count_in_zone3 > 0);
// public all info
if (id(target1_x).state != p1_x){
id(target1_x).publish_state(p1_x);
if (id(target1_y).state != p1_y){
id(target1_y).publish_state(p1_y);
float p1_m_speed = float(p1_speed) / 100.0;
if (id(target1_speed).state != p1_m_speed){
id(target1_speed).publish_state(p1_m_speed);
if (id(target1_resolution).state != p1_distance_resolution){
id(target1_resolution).publish_state(p1_distance_resolution);
if (id(target2_x).state != p2_x){
id(target2_x).publish_state(p2_x);
if (id(target2_y).state != p2_y){
id(target2_y).publish_state(p2_y);
if (id(target2_speed).state != p2_speed){
id(target2_speed).publish_state(p2_speed);
if (id(target2_resolution).state != p2_distance_resolution){
id(target2_resolution).publish_state(p2_distance_resolution);
if (id(target3_x).state != p3_x){
id(target3_x).publish_state(p3_x);
if (id(target3_y).state != p3_y){
id(target3_y).publish_state(p3_y);
if (id(target3_speed).state != p3_speed){
id(target3_speed).publish_state(p3_speed);
if (id(target3_resolution).state != p3_distance_resolution){
id(target3_resolution).publish_state(p3_distance_resolution);
// publish target info
if (id(all_target_count).state != all_target_counts){
id(all_target_count).publish_state(all_target_counts);
id(any_target_exsits).publish_state(has_target_in_zone_all);
}else if (id(any_target_exsits).state != has_target_in_zone_all){
if (id(zone1_target_count).state != target_count_in_zone1){
id(zone1_target_count).publish_state(target_count_in_zone1);
id(zone1_target_exsits).publish_state(has_target_in_zone1);
}else if (id(zone1_target_exsits).state != has_target_in_zone1){
if (id(zone2_target_count).state != target_count_in_zone2){
id(zone2_target_count).publish_state(target_count_in_zone2);
id(zone2_target_exsits).publish_state(has_target_in_zone2);
}else if (id(zone2_target_exsits).state != has_target_in_zone2){
if (id(zone3_target_count).state != target_count_in_zone3){
id(zone3_target_count).publish_state(target_count_in_zone3);
id(zone3_target_exsits).publish_state(has_target_in_zone3);
}else if (id(zone3_target_exsits).state != has_target_in_zone3){
// zout
if (id(zone_ex1_target_count).state != target_count_in_zone_ex1){
id(zone_ex1_target_count).publish_state(target_count_in_zone_ex1);
if (id(zone_ex1_target_exsits).state != has_target_in_zone_ex1){
id(zone_ex1_target_exsits).publish_state(has_target_in_zone_ex1);
if (!id(init_zone_publish)){
id(init_zone_publish) = true;
If you ticked ‘Backup’ before installing the ESPHome 2023.9 update, you should be able to go to Settings / System / Backups and then restore the ESPHome addon back to the previous version.
Thanks, that compiled just fine for my esp32dev board.
So there’s no need to use the external component for LD2450?
I just it find odd why the same default yaml working on previous version but not the latest 2023.9 update
Glad to hear you got it working.
I’m not sure about the external components but everything seems to be working fine with my ESP32 board. It may have been required previously with the ESP32-C3 boards. I noticed this in the change log for ESPHome 2023.9:
- Add support for ESP32-{S2,S3,C3} to debug component esphome#4731 by @jayme-github
I can confirm, with ESPHome 2023.9 no need for external_components. I use an ESP32-C3 and it works fine.
It can’t be related to deleting a folder
.esphome
and replacing it with the data folder as mentioned in the latest ESPHome update 2023.9 ?
I thought that was the case but i still get same error when compiling with a new yaml
It should be more than enough for the LD2450. The S2 boards don’t have bluetooth but otherwise it should be fine.
Are you still having issues using the Screek 2A YAML? We may need to wait for Screek Workshop to take a look at it and reply as the YAML that I had put together based on the Screek 2A one is working ok for me.
Have you tried cleaning the build files for that board? Does the YAML validate successfully?
Thanks for the headsup, I’ll swap d1 mini with esp32c3 that i have. Need those bluetooth proxies working.
I have one screek 2a yaml that compiled succesfully, this one
If I use the beta/stable yaml for 2a and just compile as it is without changing anything it just give me the same errors as before
Still getting the same missing component error when cleaning the build unfortunately
I am using this and it works great.
Thanks for your response.
