The distance resolution of p3 was indeed a bug, we have fixed it, thank you very much for your feedback!
Now it is:
int16_t p3_distance_resolution = (uint16_t((bytes[27] << 8) | bytes[26] ));
You can fix it in your yaml.
Now it is:
LD2450 Documentation
We have translated the hilink documentation into English using an online tool. It may not be exact, but it can help to get a reference.
Included is a new document, a temperature test document for the LD2450.
2A beta firmware V230729_3_Beta - Tri-area setup detection
We spent some time debugging and optimizing and it seems to be working so far, but itās still Beta and we canāt guarantee anything, so feel free to come along and test and experiment.
For firmware upgrades, please refer to our previous 1U documentation, and be sure to get the firmware file belonging to 2a from dropbox: OTA Update - SCREEK WORKSHOP
beta firmware file: Dropbox - human sensor 2a by SCREEK - Simplify your life
demo video: SCREEK Human Sensor 2A beta firmware V230729_3_Beta - Tri-area setup detection Demo - YouTube
Nice work done there @screek-workshop . This one is my favourite mmwave sensor and would be very happy to watch him develop. Hope to be a good alternative to the expensive fp2 from aqara.
I have, slightly changed the code from tsunglung to use internal pull up resistors and added the official documentation on my github, which is also in english
tsunglung did a great job rewriting a custom library in c++, while we simply roughed out parsing the data in yaml.
Hopefully this library will continue to add more features and be officially supported soon.
The pullup resistor approach is great, I donāt know if weāll have to do it again with the new firmware, but weāve kept an internal pullup parameter.
In the earliest firmware, this pullup was not enough and needed to trigger a high level, fortunately hilink has fixed this completely in the new firmware, making the 3.3v level well supported, which makes it perfect for the esp32.
Known issues: For Human Sensor 2A(LD2450)'s multi-person target jumping issue
Update 07-29: Weāve heard from the hilink devs that the new app feature, toggle multiplayer mode is expected to be released in mid-August. Weāre looking forward to how much simultaneous tracking can actually be effective at that time.
Some users feedback that the multi-target detection of Radar 2A will jump suddenly, and the recognition is very good when it is one, while there will be some error when it is multiple.
We talked to the development department of hilink and got this feedback:
I bought one of these sensors for testing, Iām waiting for it to arrive.
Would it be possible to define a maximum detection angle?
E.g. ignore any reading above 50Ā°?
We have consulted with the developers of ld2450 on this issue, and the response was that it will be opened gradually in the future, first to the mobile app (via Bluetooth) and later to the Bluetooth protocol.
Including the switching of multiplayer mode, it will also be such a gradual realization.
This will probably be close to the route of LD2410.
Screek Workshop | 2A beta firmware V230729_3_Beta - Tri-area setup detection | Facebook
Any video demo with exclusion zone?
For example if you leave a room, the ceiling fan/stand fan turns off
We try to be able to do some documentation like this explaining how to trigger when leaving the zone, currently if you are using our new firmware all you need to do is, set the location range of zone1 and use automation to detect when the human presence of zone1 becomes off.
Ah yes, for the location range, say if the ceiling fan is located in the center of the room around 3m high.
So that zone range Y needs to be below 2m to avoid fan detection?
In our tests, it seems that neither fans nor appliances cause the ld2450 to trigger.
Is the triggering happening at your place?
The zone function is mainly used to detect the presence of a certain zone.
We didnāt think it could be used to exclude a zone.
This is interesting.
No, i havenāt purchased yet
Bought a few mmwave sensors suggested by this forum in the past but they all keep getting triggered by fans.
So Iām curious how the multi zone solution could solve that issue
We have created a temporary website to portray all the issues regarding the 2A: https://2a.screek.io/
Some advanced radars are able to avoid signals like fans, they differentiate between information like the frequency of the target.
The LD2450 looks to be a little better radar.
Weāre still testing some newer signals like the LD1125H and hope to share them with you sometime.
Would be great if you could put a video demo with fans.
I tried tweaking the settings for my mmwave sensors but itās always getting detected.
As for the multizone, how exactly does it split the areas in a room? Would i need to just estimate which zone Iām in based on the range detected by sensor?
The documentation of the LD2450 states that placing the sensor is very important when trying to omit things like fans:
This product needs to be installed in a suitable environment. If it is used in the following environment, the
detection effect will be affected:
The presence of non-human objects in the sensing area that are in constant motion, such as animals,
curtains that are constantly swinging, large green plants facing the air vents, etc.
The presence of a large area of strong reflectors in the sensing area, which is directly in front of the
radar antenna can cause interference
For wall mounting, it is necessary to consider external interference from air conditioners, fans, etc. on
top of the room.
So unless the sensor you have filter this out in itās firmware I guess placement is very important there too.
we update a app faq: https://2a.screek.io/app-faq
The fan exclusion is pretty good in the general performance so far, and weāll try to record a video sometime.
But the new version of the LD2450, test firmware v1.23, seems to reduce the sensitivity, causing the 3d printer to be detected.
hlk says itās working on an area exclusion feature to exclude fixed interference rather than relying on the sensitivity parameter.
Weāve done some explaining in the app-faq of the information we understand.
If you donāt need x and y coordinate localization, you can wait for us to test and research a couple of new radars that are based on breathing patterns to determine humans.
Firmware updateļ¼
Coordinate input can be frustrating because the coordinates have some deviation and will move. We have added a Tolerance option.
Fixed an issue where setting the coordinates of region 0 would always result in no one triggering the region.
šŖAdjusted to set the default coordinates of the three regions to 0 so that it doesnāt show three regions triggering the first time you use it, causing confusion.
šŖ Added to set the light sensor reporting interval of 5 minutes to always report once to prevent losing updates for too long. Its current strategy is to push an update once for more than 1lux changes greater than 1 second (as fast as one second), and once if there is no change for five minutes.
šŖwill modify the zone setting when the policy of writing to flash to 15 seconds, after 15 seconds after the modification will be saved as persistent data.
