athua
(Gus)
August 28, 2023, 1:56pm
101
I have updated to your latest firmware (V230828_2_BETA) and it seems to be working well so far.
One issue that I have found is that I am getting X values from -3500 to 3500 so you may want to extend the limit from -3000 to -3500 and 3000 to 3500.
It may be worth checking with HiLink as to what the minimum and maximum values of X should be.
Edit: Another issue found is that the Zout1 Y range has been restricted to 3000. Should Y be up to 6000?
Hello, I have updated the latest firmware. Zout1 has been successfully detected, but my is a ceiling fan, y begin and y end need at least 4500 to 6000. But the upper limit only reaches 3000. Can this upper limit be adjusted?
noname.essqq:
Hi, Gus. This appears to be a bug and we will now immediately try to fix it.
@noname.essqq we are fix now.
https://docs.screek.io/2a/beta#e2de1ac445104036939c749f6b7a7ef7
In hilink’s documentation there is only a vague chart of the detection range, based on the approximate measurements inside it is about 3m left and right, in reality it seems difficult to exceed 4m left and right.
We have 4m set aside now, which should be enough for basic use.
athua
(Gus)
August 29, 2023, 6:34am
105
Thanks for applying the updates so quickly.
I have just updated to V230829_1_BETA and its looking good.
Setting the range for X from -4000 to 4000 sounds like the best option as I got a value just over 3500, so 4000 will cover up to the maximum range it is capable of.
pepe59
(Pepe59)
August 29, 2023, 9:00am
106
I read the whole thread and couldn’t find any HW info.
I have several LD2450 sensors here and would like to try this part.
What is the most suitable esp, 32 or 8266 or does it not matter?
What do you use?
thanks
athua
(Gus)
August 29, 2023, 10:59am
107
I don’t think it really matters which ESP board is used but an ESP32 would probably be better being a little more powerful.
I have connected my LD2450 to a Wemos D1 Mini ESP32 purchased from Aliexpress.
I had it working previously with a LD2410 and swapped it out for a LD2450 for testing and now have my LD2410 running off bluetooth instead of being connected to an ESP32.
It has a relatively simple serial protocol that you can build with a chip you are familiar with.
It’s the same with the ld2410.
Tks for your work.
This beta version is also updated on the github ?
athua
(Gus)
August 29, 2023, 12:46pm
110
Yes it has been updated in Github as I have used it to update my LD2450 connected to a Wemos D1 Mini ESP32 board.
Use the following link as the one you have posted is not to the main branch.
Thanks for testing it, i will update the yaml and retry again.
I don’t think so, there’s no curtains in that area.
Also, which hilink firmwarw are you using now?
use 1.2,it’s stable version.
I think i’ve got zout working now after some trial and error.
With zout enabled, it doesn’t detect the fan however presence would consistently shift between available or not available the more static your position is. I added 30- 45 seconds delay before switching any device off when presence is not detected. If i fall asleep it would probably just stop detecting
I think this has something to do with sensor that prioritise the more active target (fan) when the other target is static/not moving. Hopefully this gets fixed on the next hlk sensor update.
athua
(Gus)
August 31, 2023, 2:27am
114
That is the same thing I am experiencing which makes this sensor problematic for use with multiple zones with the current HiLink firmware. I have setup 3 zones and if there is a person in Zone 1 and another person in Zone 2, the sensor will lose track of the one moving less and so will clear the presence of one of the Zones and if that is setup for the lights, then the lights will turn off.
Hopefully the next firmware release from HiLink will enable the proper 3 target tracking that has been promoted about the LD2450 sensor.
athua
(Gus)
August 31, 2023, 5:07am
115
I noticed that the LD2450 clears the Zone Presence immediately when it doesn’t detect a target. When there is little movement, it seems to clear the presence and then detect it again in a few seconds. Adding a configurable delay to when the presence is cleared could resolve this issue.
The following code should allow the timeout for each zone to be configured and set:
number:
min_value: 0
max_value: 600
mode: box
device_class: duration
entity_category: config
unit_of_measurement: s
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
binary_sensor:
name: "Zone1 Presence"
device_class: occupancy
filters:
- delayed_off: !lambda |-
return id(zone1_x_timeout).state * 1000.0;
name: "Zone2 Presence"
filters:
return id(zone2_x_timeout).state * 1000.0;
name: "Zone3 Presence"
filters:
return id(zone3_x_timeout).state * 1000.0;
It’s a cool feature, Gus, and we’ll try to incorporate it into the firmware.
I was doing this just now, but your solution is way better than mine.
I’m not a developer, but here’s my setup based on the work of screek-workshop and Gus.
I added direction, position, angle (not very accurate but can be useful in some cases) and a general threshold for presence.
esphome:
friendly_name: ld2450b
platformio_options:
board_build.flash_mode: dio
on_boot:
- priority: 2000
then:
lambda: |-
id(any_target_exsits).publish_state(false);
id(zone1_target_exsits).publish_state(false);
id(zone2_target_exsits).publish_state(false);
id(zone3_target_exsits).publish_state(false);
id(zone_ex1_target_exsits).publish_state(false);
external_components:
- source:
type: git
url: https://github.com/screekworkshop/custom_components_support_for_screek_2a
ref: main
components: [esp32, uart]
globals:
- id: last_update_ld2450
type: unsigned long
restore_value: no
initial_value: '0'
- id: init_zone_publish
type: bool
restore_value: no
initial_value: "false"
improv_serial:
debug:
update_interval: 30s
text_sensor:
icon: mdi:information-outline
lambda: |-
return {"Configure below" };
update_interval: 1000s
lambda: |-
lambda: |-
lambda: |-
return {"Zone Exclusion 1" };
name: "Target1 Direction"
icon: mdi:arrow-up-down
name: "Target2 Direction"
name: "Target3 Direction"
name: "Target1 Position"
icon: mdi:arrow-left-right
name: "Target2 Position"
name: "Target3 Position"
number:
min_value: -4000
max_value: 4000
initial_value: -4000
mode: box
device_class: distance
unit_of_measurement: mm
icon: mdi:arrow-left-bold
step: 10
optimistic: True
restore_value: True
mode: box
min_value: -4000
max_value: 4000
initial_value: 4000
icon: mdi:arrow-right-bold
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
icon: mdi:arrow-up-bold
step: 10
optimistic: True
restore_value: True
icon: mdi:arrow-down-bold
mode: box
min_value: 0
max_value: 6000
initial_value: 6000
step: 10
optimistic: True
restore_value: True
name: Area Angle-Begin
icon: mdi:angle-acute
mode: box
min_value: -130 # In the readings, I obtained values of approximately 120º when passing behind the sensor
max_value: 130 # In the readings, I obtained values of approximately 120º when passing behind the sensor
initial_value: -130 # In the readings, I obtained values of approximately 120º when passing behind the sensor
# device_class: distance
unit_of_measurement: 'º'
step: 1
optimistic: True
restore_value: True
name: Area Angle-End
# mode: box
initial_value: 130 # In the readings, I obtained values of approximately 120º when passing behind the sensor
step: 1
optimistic: True
restore_value: True
min_value: -4000
max_value: 4000
initial_value: 0
# mode: box
step: 10
optimistic: True
restore_value: True
mode: box
min_value: -4000
max_value: 4000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
min_value: -4000
max_value: 4000
initial_value: 0
mode: box
step: 10
optimistic: True
restore_value: True
mode: box
min_value: -4000
max_value: 4000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
min_value: -4000
max_value: 4000
initial_value: 0
mode: box
step: 10
optimistic: True
restore_value: True
mode: box
min_value: -4000
max_value: 4000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
min_value: -4000
max_value: 4000
initial_value: 0
mode: box
step: 10
optimistic: True
restore_value: True
mode: box
min_value: -4000
max_value: 4000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
name: "Zone Any Timeout"
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
binary_sensor:
name: "Any Presence"
filters:
return id(zoneany_x_timeout).state * 1000.0;
filters:
filters:
filters:
name: "Zout1 Presence"
icon: mdi:account-multiple-remove
name: "All Target Counts"
accuracy_decimals: 0
icon: "mdi:counter"
unit_of_measurement: "targets"
name: "Zone1 Target Counts"
icon: "mdi:counter"
name: "Zone2 Target Counts"
icon: "mdi:counter"
name: "Zone3 Target Counts"
icon: "mdi:counter"
name: "Zout1 Target Counts"
icon: mdi:account-multiple-minus-outline
unit_of_measurement: 'mm'
state_class: measurement
accuracy_decimals: 2
unit_of_measurement: 'm/s'
device_class: speed
name: "Target1 Resolution"
# update_interval: 1s
device_class: speed
name: "Target2 Resolution"
device_class: speed
name: "Target3 Resolution"
output:
- platform: ledc
pin: GPIO2
switch:
optimistic: True
icon: mdi:account-cancel
restore_mode: RESTORE_DEFAULT_OFF
button:
- platform: restart
icon: mdi:power-cycle
entity_category: diagnostic
- platform: factory_reset
disabled_by_default: false
icon: mdi:heart-broken
uart:
tx_pin:
number: GPIO25
mode:
input: true
pullup: true
rx_pin:
number: GPIO32
mode:
input: true
pullup: true
baud_rate: 256000
parity: NONE
stop_bits: 1
data_bits: 8
debug:
direction: BOTH
dummy_receiver: True
after:
delimiter: [0X55, 0XCC]
sequence:
- lambda: |-
if ((millis() - id(last_update_ld2450)) <= 500) {
return;
id(last_update_ld2450) = millis();
// Calc X, Y, Speed and Resolution //
int16_t p1_x = (uint16_t((bytes[5] << 8) | bytes[4] ));
if ((bytes[5] & 0x80) >> 7) {
p1_x -= pow(2, 15);
} else {
p1_x = 0 - p1_x;
int16_t p1_y = (uint16_t((bytes[7] << 8) | bytes[6] ));
if ((bytes[7] & 0x80) >> 7) {
p1_y -= pow(2, 15);
} else {
p1_y = 0 - p1_y;
int p1_speed = (bytes[9] << 8 | bytes[8] );
if ((bytes[9] & 0x80) >> 7) {
p1_speed -= pow(2, 15);
} else {
p1_speed = 0 - p1_speed;
int16_t p1_distance_resolution = (uint16_t((bytes[11] << 8) | bytes[10] ));
int16_t p2_x = (uint16_t((bytes[13] << 8) | bytes[12] ));
if ((bytes[13] & 0x80) >> 7) {
p2_x -= pow(2, 15);
} else {
p2_x = 0 - p2_x;
int16_t p2_y = (uint16_t((bytes[15] << 8) | bytes[14] ));
if ((bytes[15] & 0x80) >> 7) {
p2_y -= pow(2, 15);
} else {
p2_y = 0 - p2_y;
int p2_speed = (bytes[17] << 8 | bytes[16] );
if ((bytes[17] & 0x80) >> 7) {
p2_speed -= pow(2, 15);
} else {
p2_speed = 0 - p2_speed;
int16_t p2_distance_resolution = (uint16_t((bytes[19] << 8) | bytes[18] ));
int16_t p3_x = (uint16_t((bytes[21] << 8) | bytes[20] ));
if ((bytes[21] & 0x80) >> 7) {
p3_x -= pow(2, 15);
} else {
p3_x = 0 - p3_x;
int16_t p3_y = (uint16_t((bytes[23] << 8) | bytes[22] ));
if ((bytes[23] & 0x80) >> 7) {
p3_y -= pow(2, 15);
} else {
p3_y = 0 - p3_y;
int p3_speed = (bytes[25] << 8 | bytes[24] );
if ((bytes[25] & 0x80) >> 7) {
p3_speed -= pow(2, 15);
} else {
p3_speed = 0 - p3_speed;
int16_t p3_distance_resolution = (uint16_t((bytes[27] << 8) | bytes[26] ));
float p1_a = (p1_x);
float p1_b = (p1_y);
float p1_c = ((p1_a / p1_b) * 180 / 3.14159265359);
if (p1_x == 0) {
id(target1_angle).publish_state(0);
} else {
id(target1_angle).publish_state(p1_c);
float p2_a = (p2_x);
float p2_b = (p2_y);
float p2_c = ((p2_a / p2_b) * 180 / 3.14159265359);
if (p2_x == 0) {
id(target2_angle).publish_state(0);
} else {
id(target2_angle).publish_state(p2_c);
float p3_a = (p3_x);
float p3_b = (p3_y);
float p3_c = ((p3_a / p3_b) * 180 / 3.14159265359);
if (p3_x == 0) {
id(target3_angle).publish_state(0);
} else {
id(target3_angle).publish_state(p3_c);
int16_t area_x_min = id(area_x_begin).state; // - x_tolerance;
int16_t area_x_max = id(area_x_end).state; // + x_tolerance;
int16_t area_y_min = id(area_y_begin).state; // - y_tolerance;
int16_t area_y_max = id(area_y_end).state; // + y_tolerance;
int16_t area_angle_min = id(area_angle_begin).state; // + y_tolerance;
int16_t area_angle_max = id(area_angle_end).state; // + y_tolerance;
bool p1_valid = ((p1_x != 0 || p1_y > 0) && p1_x >= area_x_min && p1_x <= area_x_max && p1_y >= area_y_min && p1_y <= area_y_max && p1_c >= area_angle_min && p1_c <= area_angle_max);
bool p2_valid = ((p2_x != 0 || p2_y > 0) && p2_x >= area_x_min && p2_x <= area_x_max && p2_y >= area_y_min && p2_y <= area_y_max && p2_c >= area_angle_min && p2_c <= area_angle_max);
bool p3_valid = ((p3_x != 0 || p3_y > 0) && p3_x >= area_x_min && p3_x <= area_x_max && p3_y >= area_y_min && p3_y <= area_y_max && p3_c >= area_angle_min && p3_c <= area_angle_max);
int16_t target_count_in_zone_ex1 = 0;
int16_t zone_ex1_x_min = id(zone_ex1_x_begin).state; // - x_ex_tolerance;
int16_t zone_ex1_x_max = id(zone_ex1_x_end).state; // + x_ex_tolerance;
int16_t zone_ex1_y_min = id(zone_ex1_y_begin).state; // - y_ex_tolerance;
int16_t zone_ex1_y_max = id(zone_ex1_y_end).state; // + y_ex_tolerance;
bool p1_zone_ex_enter = false;
bool p2_zone_ex_enter = false;
bool p3_zone_ex_enter = false;
if (id(zone_ex1_enable).state) {
if (p1_valid) {
if (p1_x >= zone_ex1_x_min && p1_x <= zone_ex1_x_max && p1_y >= zone_ex1_y_min && p1_y <= zone_ex1_y_max) {
p1_zone_ex_enter = true;
target_count_in_zone_ex1 ++;
if (p2_valid) {
if (p2_x >= zone_ex1_x_min && p2_x <= zone_ex1_x_max && p2_y >= zone_ex1_y_min && p2_y <= zone_ex1_y_max) {
p2_zone_ex_enter = true;
if (p3_valid) {
if (p3_x >= zone_ex1_x_min && p3_x <= zone_ex1_x_max && p3_y >= zone_ex1_y_min && p3_y <= zone_ex1_y_max) {
p3_zone_ex_enter = true;
bool has_target_in_zone_ex1 = (target_count_in_zone_ex1 > 0);
int16_t all_target_counts = 0;
if (p1_valid && !p1_zone_ex_enter) {
all_target_counts ++;
if (p2_valid && !p2_zone_ex_enter) {
if (p3_valid && !p3_zone_ex_enter) {
bool has_target_in_zone_all = (all_target_counts > 0);
int16_t target_count_in_zone1 = 0;
int16_t zone1_x_min = id(zone1_x_begin).state; // - x_tolerance;
int16_t zone1_x_max = id(zone1_x_end).state; // + x_tolerance;
int16_t zone1_y_min = id(zone1_y_begin).state; // - y_tolerance;
int16_t zone1_y_max = id(zone1_y_end).state; // + y_tolerance;
if (p1_x >= zone1_x_min && p1_x <= zone1_x_max && p1_y >= zone1_y_min && p1_y <= zone1_y_max) {
target_count_in_zone1 ++;
if (p2_x >= zone1_x_min && p2_x <= zone1_x_max && p2_y >= zone1_y_min && p2_y <= zone1_y_max) {
if (p3_x >= zone1_x_min && p3_x <= zone1_x_max && p3_y >= zone1_y_min && p3_y <= zone1_y_max) {
bool has_target_in_zone1 = (target_count_in_zone1 > 0);
int16_t target_count_in_zone2 = 0;
int16_t zone2_x_min = id(zone2_x_begin).state; // - x_tolerance;
int16_t zone2_x_max = id(zone2_x_end).state; // + x_tolerance;
int16_t zone2_y_min = id(zone2_y_begin).state; // - y_tolerance;
int16_t zone2_y_max = id(zone2_y_end).state; // + y_tolerance;
if (p1_x >= zone2_x_min && p1_x <= zone2_x_max && p1_y >= zone2_y_min && p1_y <= zone2_y_max) {
target_count_in_zone2 ++;
if (p2_x >= zone2_x_min && p2_x <= zone2_x_max && p2_y >= zone2_y_min && p2_y <= zone2_y_max) {
if (p3_x >= zone2_x_min && p3_x <= zone2_x_max && p3_y >= zone2_y_min && p3_y <= zone2_y_max) {
bool has_target_in_zone2 = (target_count_in_zone2 > 0);
int16_t target_count_in_zone3 = 0;
int16_t zone3_x_min = id(zone3_x_begin).state; // - x_tolerance;
int16_t zone3_x_max = id(zone3_x_end).state; // + x_tolerance;
int16_t zone3_y_min = id(zone3_y_begin).state; // - y_tolerance;
int16_t zone3_y_max = id(zone3_y_end).state; // + y_tolerance;
if (p1_x >= zone3_x_min && p1_x <= zone3_x_max && p1_y >= zone3_y_min && p1_y <= zone3_y_max) {
target_count_in_zone3 ++;
if (p2_x >= zone3_x_min && p2_x <= zone3_x_max && p2_y >= zone3_y_min && p2_y <= zone3_y_max) {
if (p3_x >= zone3_x_min && p3_x <= zone3_x_max && p3_y >= zone3_y_min && p3_y <= zone3_y_max) {
bool has_target_in_zone3 = (target_count_in_zone3 > 0);
if (id(target1_x).state != p1_x) {
id(target1_x).publish_state(p1_x);
if (id(target1_y).state != p1_y) {
id(target1_y).publish_state(p1_y);
float p1_m_speed = float(p1_speed) / 100.0;
if (id(target1_speed).state != p1_m_speed) {
id(target1_speed).publish_state(p1_m_speed);
if (id(target1_resolution).state != p1_distance_resolution) {
id(target1_resolution).publish_state(p1_distance_resolution);
if (id(target2_x).state != p2_x) {
id(target2_x).publish_state(p2_x);
if (id(target2_y).state != p2_y) {
id(target2_y).publish_state(p2_y);
if (id(target2_speed).state != p2_speed) {
id(target2_speed).publish_state(p2_speed);
if (id(target2_resolution).state != p2_distance_resolution) {
id(target2_resolution).publish_state(p2_distance_resolution);
if (id(target3_x).state != p3_x) {
id(target3_x).publish_state(p3_x);
if (id(target3_y).state != p3_y) {
id(target3_y).publish_state(p3_y);
if (id(target3_speed).state != p3_speed) {
id(target3_speed).publish_state(p3_speed);
if (id(target3_resolution).state != p3_distance_resolution) {
id(target3_resolution).publish_state(p3_distance_resolution);
if (id(all_target_count).state != all_target_counts) {
id(all_target_count).publish_state(all_target_counts);
if (id(any_target_exsits).state != has_target_in_zone_all) {
id(any_target_exsits).publish_state(has_target_in_zone_all);
if (id(zone1_target_count).state != target_count_in_zone1) {
id(zone1_target_count).publish_state(target_count_in_zone1);
if (id(zone1_target_exsits).state != has_target_in_zone1) {
id(zone1_target_exsits).publish_state(has_target_in_zone1);
if (id(zone2_target_count).state != target_count_in_zone2) {
id(zone2_target_count).publish_state(target_count_in_zone2);
if (id(zone2_target_exsits).state != has_target_in_zone2 ) {
id(zone2_target_exsits).publish_state(has_target_in_zone2);
if (id(zone3_target_count).state != target_count_in_zone3) {
id(zone3_target_count).publish_state(target_count_in_zone3);
if (id(zone3_target_exsits).state != has_target_in_zone3) {
id(zone3_target_exsits).publish_state(has_target_in_zone3);
if (id(zone_ex1_target_count).state != target_count_in_zone_ex1) {
id(zone_ex1_target_count).publish_state(target_count_in_zone_ex1);
if (id(zone_ex1_target_exsits).state != has_target_in_zone_ex1) {
id(zone_ex1_target_exsits).publish_state(has_target_in_zone_ex1);
id(init_zone_publish) = true;
// Angle, Position and Direction //
if (p1_speed == 0) {
id(target1_direction).publish_state("Static");
} else if (p1_speed > 0) {
id(target1_direction).publish_state("Moving away");
} else if (p1_speed < 0) {
id(target1_direction).publish_state("Approaching");
if (p2_speed == 0) {
id(target2_direction).publish_state("Static");
} else if (p2_speed > 0) {
id(target2_direction).publish_state("Moving away");
} else if (p2_speed < 0) {
id(target2_direction).publish_state("Approaching");
if (p3_speed == 0) {
id(target3_direction).publish_state("Static");
} else if (p3_speed > 0) {
id(target3_direction).publish_state("Moving away");
} else if (p3_speed < 0) {
id(target3_direction).publish_state("Approaching");
if (p1_x == 0) {
id(target1_position).publish_state("Static");
} else if (p1_x > 0) {
id(target1_position).publish_state("Right");
} else if (p1_x < 0) {
id(target1_position).publish_state("Left");
if (p2_x == 0) {
id(target2_position).publish_state("Static");
} else if (p2_x > 0) {
id(target2_position).publish_state("Right");
} else if (p2_x < 0) {
id(target2_position).publish_state("Left");
if (p3_x == 0) {
id(target3_position).publish_state("Static");
} else if (p3_x > 0) {
id(target3_position).publish_state("Right");
} else if (p3_x < 0) {
id(target3_position).publish_state("Left");
if ((p1_valid) || (p2_valid) || (p3_valid)) {
id(led).set_level(0.0);
} else {
id(led).set_level(1.0);
I just saw @screek-workshop post on static detection with different mmwave sensor on the facebook group.
Apparently LD2450 doesn’t have full static detection?
That would explain why i still have to move around a bit when i was testing in a room with no interference (no fans etc)
Luke5500
(Luke Draper)
September 1, 2023, 3:20am
120
Hi there, I have looked all over and even asked Hi-Link with no luck. Could you tell me which connecter type you used here?
