I’m having trouble with getting the voltage detection to work on a Etekcity Voltson (smart plug with power monitoring). I have been able to successfully flash the device and can operate the switch from HA.
I followed the following docs to get to this point:
ESPHome Device - Docs for the EU version of the plug
Tasmota Device - To compare the pinout for the US version of the plug
(And some helpful hints in a previous post to this one!)
The ESPHome docs do say that, in this implementation of the HLW8012 component, the SEL_PIN is permanently pulled high and this prevents direct current monitoring (only power and voltage). An example to calculate the current is included in the doc.
The only sensor result I get is the power (wattage). The voltage is constantly reported as 0.00 V. Without a voltage value, the calculated current sensor is invalid. Toggling the relay on does not have any effect on the sensor values.
I have confirmed the pin mapping is accurate and compared the sensor YAML syntax and formatting against the ESPHome sensor and HLW8012 docs. Everything looks to be correct.
According to the HLW8012 docs the CF_PIN reports the power (wattage) and the CF1_PIN reports the current and voltage based on selection. In this case it will only report voltage as it’s permanently pulled high. I know the CF_PIN is correct because I get values on for the power sensor.
I guess the docs could be off for the CF1_PIN but there is no indication on the device anywhere about a hardware version to further investigate.
I’m open to suggestions if anyone has one.
Many Thanks!
Here's the code:
esphome:
... <setup details> ...
status_led:
pin:
number: GPIO5
output:
- platform: gpio
pin: GPIO16
switch:
- platform: gpio
pin: GPIO4
restore_mode: RESTORE_DEFAULT_OFF
on_turn_on:
- output.turn_on: led1
on_turn_off:
- output.turn_off: led1
binary_sensor:
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: true
on_press:
- switch.toggle: switch1
- platform: hlw8012
sel_pin: 0 #Example sets to 0. Tried GPIO15 also with no effect on the issue.
cf_pin: GPIO13
cf1_pin: GPIO12
voltage:
power:
on_value:
then:
- sensor.template.publish:
state: !lambda 'return id(hlw8012_wattage).state / id(hlw8012_voltage).state;'
update_interval: 60s
initial_mode: VOLTAGE
change_mode_every: 4294967295 # basically never
name: "Current (calculated)"
