Hello!
I’m glad that so far everything works like a charm with HASS.
I was able to get all my Homematic stuff integrated and publish things I want with HomeKit.
The only thing I can’t get to work is the “sensor” named above. All the other thermal stuff is marked as “climate” and was easily accepted by HomeKit.
The documentation tells me that its need to be the following conditions:
All sensors that have
as theirunit_of_measurement
andhumidity
as theirdevice_class
And when I take a look at the attributes, I see that it looks like this:
Address: LEQ1000266:1
Model: HM-WDS10-TH-O
Entity type: generic
Parameter: HUMIDITY
Function: Weather
Value_state: valid
unit of measurement: '%'.
device_class: Humidity
friendly_name: outdoor sensor humidity
This is my configuration: (referenced in configuration.yaml)
- name: HASS bridge 2
port: 21065
- Filter:
include_entity_globs:
- climate.*_wall_thermostat
- light.*
- cover.*
include_entities:
- input_boolean.swalarm
- input_boolean.cinema
- switch.kuche_switch_input
- switch.reading_lampwz
- sensor.outdoor_feeler_humidity
- sensor.outdoor_temperature
Maybe some see somthing I dont see or knows somthing I don’t know and can help me out.
Many thx and cheers
Marco
