Hello Forum,
i’m running HA and a Homematic CCU3 on different devices in the same network. All Homatic and Homatic IP devices show up as entities in HA. Only the Homatic device HmIP-WUA does not show up and I have now idea why not.
Hope anyone has a idea
It‘s not supported by the core integration. You have to switch to the new integration if you need support for new devices. You can install the new integration as a custom component. The repository can be found here: GitHub - danielperna84/custom_homematic: Custom Home Assistant Component for HomeMatic
Sorry I was not able to find that integration following the Manual configuration steps as it can’t be found in the integrationslist
I got it now and it seems to work
