I’m building an ESPHome-driven controller for my SGC SG-230 antenna matching unit. I’m using a NodeMCU borad (because I has laying around), an Elegoo 4-channel relay board for the control lines, and an opto-isolated input for sense the tune state.
The SG-230 has a 12V power feed and a tri-state control line. 12V means “Tune”, 0V means “reset” with floating meaning do nothing.
I currently have the following code.
The current arrangement requires the Tune and Reset to be controlled separately, whereas with a physical switch, it would simply be a centre-biased single-pole 2-way toggle switch.
Could I implement such a switch in esphome or HA?
switch:
# SG-230 Power switch
- platform: gpio
pin: D3
inverted: True
restore_mode: RESTORE_DEFAULT_OFF
# Relays D4 and D5 are configured to "Tune" or "Reset" the SG-230
# D4 NO is connected to 12V
# D5 NO is connected to 0V
# The control line to the SG-230 is connected to the common of both relays
# The control line is also connected to 12V and 0V via hi-value resistors to help it "float"
# D4 and D5 are interlocked to prevent them both being closed.
# SG-230 "Tune"
- platform: gpio
pin: D4
inverted: True
interlock: &sg230_interlocks [sg_230_tune, sg_230_reset]
# SG-230 "Reset"
- platform: gpio
pin: D5
inverted: True
interlock: *sg230_interlocks
