Ho to remove API-Encryption
I activated encryption, recompiled and uploaded the firmware, and added the key in Homeassistant.
Since I made several changes to the firmware and suddenly nothing works anymore, I want to make sure, it’s not the encryption.
So I removed the encryption from the ESPhome device configuration, compiled and uploaded it.
But somehow all the entities of this device are inactive in HA.
I guess it’s because HA still thinks the API is encrypted.
W][api.connection:084]: 192.168.17.27: Reading failed: BAD_INDICATOR errno=11
But I cannot delete devices from HA.
How do I tell HA to not encrypt the communication with the formerly encrypted device anymore?
Just remove/add back the ESP node in HA no ?
Yes, you are right. I always get confused with the aggregated view of the integration and forgot, that you can open one device, and then remove it.
