Hi there,
I am running HassIO since a good time on Debian12. For some reason I am not able to connect to it as port 8123 for the WebGUI appears to be closed.
I did some troubleshooting but do not know enough from the details so I did not succeed.
When I try to access hoas.server.my on port 8123 I am getting connection refused.
I checked the services on the system:
root@hoas:~# systemctl status hassio-supervisor.service
● hassio-supervisor.service - Hass.io supervisor
Loaded: loaded (/etc/systemd/system/hassio-supervisor.service; enabled; preset: enabled)
Active: active (running) since Fri 2023-09-08 09:10:24 CEST; 1min 18s ago
Process: 302667 ExecStartPre=/usr/bin/docker stop hassio_supervisor (code=exited, status=0/SUCCESS)
Main PID: 302672 (docker)
Tasks: 6 (limit: 4648)
Memory: 12.1M
CGroup: /system.slice/hassio-supervisor.service
└─302672 docker container wait hassio_supervisor
Sep 08 09:10:24 hoas systemd[1]: Starting hassio-supervisor.service - Hass.io supervisor...
Sep 08 09:10:24 hoas docker[302667]: hassio_supervisor
Sep 08 09:10:24 hoas systemd[1]: Started hassio-supervisor.service - Hass.io supervisor.
Sep 08 09:10:24 hoas hassio-supervisor[302672]: [INFO] Starting the Supervisor...
Sep 08 09:10:25 hoas hassio-supervisor[302693]: hassio_supervisor
I even restarted Docker service, still no success.
I can confirm there is no process listening:
root@hoas:/var/log# netstat -anp| grep LIST
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 577/sshd: /usr/sbin
tcp 0 0 0.0.0.0:4357 0.0.0.0:* LISTEN 302561/docker-proxy
tcp 0 0 127.0.0.54:53 0.0.0.0:* LISTEN 463/systemd-resolve
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 463/systemd-resolve
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 463/systemd-resolve
tcp 0 0 0.0.0.0:8086 0.0.0.0:* LISTEN 303827/docker-proxy
tcp 0 0 0.0.0.0:8088 0.0.0.0:* LISTEN 303771/docker-proxy
tcp6 0 0 :::22 :::* LISTEN 577/sshd: /usr/sbin
tcp6 0 0 :::4357 :::* LISTEN 302568/docker-proxy
tcp6 0 0 :::5355 :::* LISTEN 463/systemd-resolve
tcp6 0 0 :::8086 :::* LISTEN 303832/docker-proxy
tcp6 0 0 :::8088 :::* LISTEN 303779/docker-proxy
Anyone having an idea how to get the frontend up and running again?
/KNEBB
