Hobot Legee 688 (vaccuum and cleaner)
Hi all,
Did anyone already try to connect a Hobot Legee 688 (vaccuum and cleaner). I am really hesitating between this one and the Braava jet M6.
The Braava is 600€, when the Hobot is 350€. They are both on top of the charts that I read.
The braava has a HA integration. I didn’t find anything for the hobot. It is also a connect device, so it should be possible …
Any info is welcome …
Kr,
Frederic
Also looking at this vacuum cleaner. Did you buy it and try to connect?
Finally got the Braava :wink:
And how it works with home assistant?
Yes, the braava has an integration for the control.
The most important for me, is the ability to start/stop (especially, to automate the cleaning, when the vacuum robot finish), and also to be able to start lights if the robot is cleaning at night (because, it works with camera, so, it doesn’t work in full dark)
I regret that it’s not possible to get the cleaning map. But there is a non official dev, that I need to test for it (easy install with HACS)
