Oscar1
June 20, 2025, 7:41am
1
Hi people,
My dashboard has a few picture entity_cards that look like small buttons.
I have the following tap_action and hold_action
- type: vertical-stack
cards:
- type: markdown
content: |-
{% if float(states('input_number.hlp_sofa_level')) == 0 %}
Sofa
{% else %}
{{states('input_number.hlp_sofa_level')|round()-64 }}
{% endif %}
theme: happy
- show_state: false
show_name: true
type: picture-entity
entity: button.lr_floorlamp_on
image: /local/plaatjes/Standing_1.png
tap_action:
action: call-service
service: input_text.set_value
value: Seq/SOFON
entity_id: input_text.hlp_lv_textcommand
hold_action:
value: RF/SofOF
Both the tap_action and hold_action work when I press or hold the picture-element from the PC. That is, the text of the input_text.hlp_lv_textcommand changes as seen in the Developer tools
When I interact with the picture-element on my Android phone, the tap_action works, but the hold_action does not
woempiej
(Woempiej)
June 28, 2025, 7:41pm
2
Please check on github;
opened 09:09AM - 16 Dec 24 UTC
### Checklist
- [X] I have updated to the latest available Home Assistant versi… on.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
- [X] I have tried reproducing the issue in [safe mode](https://www.home-assistant.io/blog/2023/11/01/release-202311/#restarting-into-safe-mode) to rule out problems with unsupported custom resources.
### Describe the issue you are experiencing
When using a image element inside a picture-elements card, the hold_action (long press) is not working. After the long press, we see some visual response in the bottom left of the screen but the action does not trigger.
I've tested that this doesn't happen using the browser version of lovelace so It seems it is only manifesting in with the android app. I opened a [issue there](https://github.com/home-assistant/android/issues/4908) but was forwarded here.
I include a reproducible snippet (might have to change the entity to something that exists)
type: picture-elements
image: https://demo.home-assistant.io/stub_config/floorplan.png
elements:
- type: image
image: >-
https://images.rawpixel.com/image_png_800/cHJpdmF0ZS9sci9pbWFnZXMvd2Vic2l0ZS8yMDI0LTAxL2Rlc2lnbndpdGhtZTA5X2FfbGlnaHRfYnVsYl9pbl90aGVfc3R5bGVfb2ZfaHlwZXItcmVhbGlzdGljX2lsbF9iMTE2ZmI3Zi1kYzc4LTQ1MDEtYWQwNC05NDY4YjVlNzU2ZjAucG5n.png
style:
top: 50%
left: 50%
width: 15%
tap_action:
action: toggle
entity: light.bathroom_office
take notice of the flashing on the bottom left corner
https://github.com/user-attachments/assets/43d7a3fd-e617-4bbe-847f-c73162cb7ce1
### Describe the behavior you expected
When long pressing the icon, the defined hold_action triggers (as it happens in non-android envs)
https://github.com/user-attachments/assets/5e8e6189-a9e7-4f68-93a4-c3a33c730537
### Steps to reproduce the issue
1. Create a widget as defined in the above snippet
2. Change the entity to something that exists in your system
3. Long press the bulb image
### What version of Home Assistant Core has the issue?
core-2024.12.3
### What was the last working version of Home Assistant Core?
core-2024.11.X
### In which browser are you experiencing the issue with?
Android 14 (One UI 6.1)
### Which operating system are you using to run this browser?
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
_No response_
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
_No response_
Having the same issue
type: picture
tap_action:
action: perform-action
entity_id:
- media_player.woonkamer
media_content_type: TUNEIN
media_content_id: speel qmusic op woonkeuken
perform_action: media_player.play_media
image: /local/tmp/Qmusic.png
hold_action:
entity_id: media_player.woonkamer
media_content_id: speel qmusic op overal
