[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 7.2.9
You are running the latest version of this add-on.
System: HassOS 4.16 (amd64 / qemux86-64)
Home Assistant Core: 0.117.6
Home Assistant Supervisor: 2020.11.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
patching file nodes/ui_base.html
Hunk #1 FAILED at 531.
1 out of 1 hunk FAILED -- saving rejects to file nodes/ui_base.html.rej
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Why do i do the updates from work
now i have a angry wife at home
Should be solved in 7.9.10
restore only Node-red to previous version from back-up , I made in that way
Can i ask what are you using nodered for that can make your wife angry? (just looking for ideas to make mine angry too
You are on the wrong forum then. This one is to make them happy.
Same error here. Tried to restore Node-Red only but could not get it to work again. Restored the whole image and now it works again.Glad I make a backup every night!
19/11 15:00 Just upgraded to version 7.2.10 and I can confirm that the update went well!
Motion detection to control lights. So if nodered dies the lights wont turn on.
