Hombli integration
Hello everyone,
I already looked around but couldn’t immediately find anything about the Hombli smart trv.
Can anyone tell me if this (see attachment) works in HA?
Thanks for every response.
Hi Bart Teuwen,
95% chance it works with the Tuya smartlife app as it is probably Tuya based. If it does, there is a core Tuya integration and several available Custom Integrations available from GitHub using the HACS Loader.
Thank you for your response.
Yes, via tuya I see the thermostat, but I can only turn it off and on but cannot set the temperature. Is there a solution for that?
Thank you in advance!
There are also at least 3 custom integrations that work with Tuya devices, that’s how convoluted Tuya stuff is.
The 3 I know about are all located in GitHub from different authors. You can get to them that way or using HACS to install them.
Personally I use the core one and live with the missing stuff because Tuya stuff is,… special.
Thank you very much for your response.
I have already tried some GitHub items, but so far I have not found any item that allows temperature adjustment. Do you know someone who can do that?
