Home app doesn't find any accessories HomeKit
Hi guys,
I’m having some troubles with HomeKit. On a past installation of hassbian and HomeBridge everything worked great, since then I moved to a new home and so to a new network provider and a new router. I decide to make a new installation of HA this time with Hass.io. Everything are great except HomeKit, I already tried only homekit:, with include_domains: and without it, nothing seems to work. Already tried the auto_start: false and start it later.
On the Home App I enter the pin code and after that keep on the screen to add accessories that is empty.
https://user-images.githubusercontent.com/309515/42729322-3b4100e2-8789-11e8-957e-928b763e8c72.PNG
Any suggestions how to solve the problem ?
Just to clarify, the Pin code shows up inside Home Assistant, right?
If not, try this.
Otherwise this seems to be a network issue. You might want to take a look at the troubleshooting section in the doc. Especially this and the following ones.
EYes the pin code shows on notification homescreen.
The deletion of the state file didn’t helped. I will try to change from lan to wifi on the rpi.
They say “ check the router configuration”, there are some specific configuration to do ?!
Thank you for the reply @cdce8p
@phoenixtrigo I haven’t had any issues with the default settings. However, from what I’ve read in the past some routers might need specific settings to allow HomeKit to work. You could also try to search the web for your router and just “HomeKit”, since Home Assistant relies on the same protocol other HomeKit devices use.
