using broadlink rm pro to enable the control in home assistant for my Moritz 433Mhz motor blinds… all is working fin in e-control app… i managed to get the code… as per below;; but im getting this error…
switches: [source /config/configuration.yaml:205]
switch 1:
platform: broadlink
host: 172.25.254.68
mac: ‘xxxxxxxxxxxxx’
timeout: 15
type: rm2_pro_plus
switches:============>>>> line 205 is the error
Stair_Blind:
friendly_name: “Stair Blind”
command_on: ‘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’
command_off: ‘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’
hi,
i just put xxxxxx for the sake of argument, but
its already usinf the actual mac address already… thats what u can see the output log… the error is on line xx where the “switches” keyword.
2018-01-03 17:25:50 ERROR (MainThread) [homeassistant.components.switch.broadlink] Did not received any signal
2018-01-03 17:25:50 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1964620624-28>
2018-01-03 17:25:50 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Broadlink switch, message=Did not received any signal, service_call_id=1964620624-29>
2018-01-03 17:25:50 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.notification_3, old_state=None, new_state=<state persistent_notification.notification_3=notifying; title=Broadlink switch, message=Did not received any signal @ 2018-01-03T17:25:50.075389+11:00>>
2018-01-03 17:25:50 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1964620624-29>
2018-01-03 17:25:51 WARNING (SyncWorker_4) [homeassistant.components.switch.neato] Neato connection error: 404 Client Error: Not Found for url: https://nucleo.neatocloud.com/vendors/neato/robots/OPS23416-884AEADD916C/messages
please change the command on from your above config to
command_on: ‘6s28zKDM2goM3Mz6vVoNoKDdvc29vNvPDM3woM3MyqvfTaCg3Nzb28zwzNzwrw29z6vV8NoPTdvc29vNvKDNvfCgrNzbz6vqDfT03b3MzM9NvcoPTb3NuqvfTaD03NzNv0zb2g9Nvc2/q9Wg2vDdvdvL2/Db3KD029zb+r1aDaCg2s3NvbzKDM3wrwzc+r1fDaoKoN29zb29vKDM3woM3Kq9oN8PDc3by9ug29ygoNvc27qr2g2vTdvc29vNvKDM3KCgrNzM+vOqqqo=’
all my hex codes is from the econtrol that i sniffed using vera broadlink plugin… i already did the hex conversion from the link u mentioned… let me try ur code… any advice in convertinf the hex code?
try one by one command. sometime you have to put double command this happen with tc2 and some wall switch.
example command: 12345 then has to be 1234512345
from 1513684269:
from 1513684270:
