Home Assisatnt upgraded to 2020-12-7 and now NODE RED can't connect
I have upgraded HA to the new 202-12-7 version and now node red issues this password error.
What is the fix for this? I have the node red add on > node-red-contrib-home-assistant version 0.3.2
I apologize for posting this in the OS forum. As I did not see this forum until after I had posted.
12/24/2020, 11:27:46 AMnode: Home Assistantmsg : string[150]
"Home assistant connection failed with error: Connection to home assistant could not be established with config: 192.168.1.110:8123 "
FInally figured this out. Node red was running an old home assistant node. Not the websocket version. I wound up deleting the node red docker container and reinstalling node red. Then I installed the websocket version of home assistant in node red, created a long lived token in HA and pasted that into one of the newly created HA nodes for home assistant for the credentials. If I could have figured out a way to delete the other node of home assistant, I probably would not have had to delete and re-isntall the docker container. Oh well, I needed the practice I guess. Been working on this issue all week.
