Home assistan broken after restoring from back-up
Hi! My Home Assistant on NUC crashed. It kept rebooting and did not load. Took another SSD and flashed a clean system on it. Used a full back-up to restore. Now after this the add-ons are black-white. When I click start, nothing happens. Mosquitto is working, as I can control my Tasmota devices but shows red dot, not green. Same with Spotify, add-on works as should, but it is grayscale and has a red dot. Have uninstalled and installed, no help… I can not even start File editor, nothing happens when I click Start.
I had the Supervised version before running in Ubuntu Docker. Did a clean install on NUC with HA op sys
After Core Upgrade 9.1 almost all started working
