Hello!
I recently upgraded Home Assistant to version 0.105.3 and Mikrotik HEX POE to version 6.46.3. After that, the device tracker stopped requesting information from CAPsMAN, which is configured on Mikrotik, now tracking works only on DHCP, which does not suit me at all. Initially, Mikrotik was configured through a yaml file, I tried to configure it through integration, but this did not work.
I want to note that in the bundle of versions of Home Assistant 0.105.2 + RouterOS 6.46.2 everything worked fine.
What could cause the problem?
Try start a issue on github.
Describe your problem and fill in the information needed.
