hi, updating the system to 0.105.1 I found that the system is much slower than the previous version. the loading of the ui-lovelace interface is very slow and after some time from its start, the system disconnects and becomes inaccessible. unfortunately I can not find logs to understand what the errors may be, although anyway I updated netatmo and samsungtv according to the new settings.
so I went back to version 0.104.3 and everything seems to work again
Without any logs or info from the system like top for example it’s impossible to tell what goes wrong with your system.
i remove nmap and ble scanning and now work
Here after restart HA is fast. Within some hours I see a lag and system become slow.
Before upgrade this was not there.
I don’t see any errors etc.
Do you see HA consuming more and more RAM over time?
not that much around 15-20 MB more. Only thing thats back now is this error:
2020-02-08 17:36:19 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2910551376] Client exceeded max pending messages [2]: 512
Before it wasn’t there also
