Hello!
I’m using Ubuntu 18.04 in a virtual machine and running Home assistant (HA) and AppDaemon (AD) using docker-compose. I’m a new user and have been playing with this for about a week.
This is the docker-compose.yml I’m using:
version: "3"
services:
homeassistant:
container_name: home-assistant
image: homeassistant/home-assistant:0.110.1
volumes:
- /home/$USER/hass/docker_files/homeassistant/config:/config
environment:
- TZ=America/New_York
restart: always
network_mode: host
appdaemon:
depends_on:
- homeassistant
container_name: appdaemon
image: acockburn/appdaemon:4.0.3
volumes:
- /home/$USER/hass/docker_files/appdaemon:/conf
ports:
- 5050:5050
restart: always
This is the appdaemon.yaml
appdaemon:
time_zone: "America/New_York"
latitude: !secret latitude
longitude: !secret longitude
elevation: !secret elevation
title: Test
status_update: none
plugins:
HASS:
type: hass
ha_url: "http://localhost:8123"
token: !secret token
hadashboard:
dashboard_dir: ./dashboards
http:
url: http://127.0.0.1:5050
password: !secret ad_password
api:
admin:
The issue I’m having is that when I try to run both HA and AD using docker compose I keep getting connection errors.
appdaemon | 2020-05-23 08:03:55.389055 INFO AppDaemon: AppDaemon Version 4.0.3 starting
appdaemon | 2020-05-23 08:03:55.389186 INFO AppDaemon: Python version is 3.8.2
appdaemon | 2020-05-23 08:03:55.389255 INFO AppDaemon: Configuration read from: /conf/appdaemon.yaml
appdaemon | 2020-05-23 08:03:55.389317 INFO AppDaemon: Added log: AppDaemon
appdaemon | 2020-05-23 08:03:55.389415 INFO AppDaemon: Added log: Error
appdaemon | 2020-05-23 08:03:55.389502 INFO AppDaemon: Added log: Access
appdaemon | 2020-05-23 08:03:55.389602 INFO AppDaemon: Added log: Diag
appdaemon | 2020-05-23 08:03:55.400465 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
appdaemon | 2020-05-23 08:03:55.406492 INFO HASS: HASS Plugin Initializing
appdaemon | 2020-05-23 08:03:55.406638 INFO HASS: HASS Plugin initialization complete
appdaemon | 2020-05-23 08:03:55.406979 INFO AppDaemon: Initializing HTTP
appdaemon | 2020-05-23 08:03:55.407238 INFO AppDaemon: Using 'ws' for event stream
appdaemon | 2020-05-23 08:03:55.414304 INFO AppDaemon: Starting API
appdaemon | 2020-05-23 08:03:55.416407 INFO AppDaemon: Starting Admin Interface
appdaemon | 2020-05-23 08:03:55.416636 INFO AppDaemon: Starting Dashboards
appdaemon | 2020-05-23 08:03:55.419098 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
appdaemon | 2020-05-23 08:03:55.423195 INFO AppDaemon: App 'hello_world' added
appdaemon | 2020-05-23 08:03:55.423767 INFO AppDaemon: Found 1 total apps
appdaemon | 2020-05-23 08:03:55.424042 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
appdaemon | 2020-05-23 08:03:55.424696 INFO AppDaemon: Running on port 5050
appdaemon | 2020-05-23 08:04:40.001883 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
appdaemon | 2020-05-23 08:04:45.004781 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
But if I run AD from the comand line using the same configuration file, it works correctly:
$ appdaemon -c /home/$USER/hass/docker_files/appdaemon
2020-05-23 07:05:42.027019 INFO AppDaemon: AppDaemon Version 4.0.3 starting
2020-05-23 07:05:42.027135 INFO AppDaemon: Python version is 3.7.7
2020-05-23 07:05:42.027219 INFO AppDaemon: Configuration read from: /home/user/hass/docker_files/appdaemon/appdaemon.yaml
2020-05-23 07:05:42.027303 INFO AppDaemon: Added log: AppDaemon
2020-05-23 07:05:42.027395 INFO AppDaemon: Added log: Error
2020-05-23 07:05:42.027478 INFO AppDaemon: Added log: Access
2020-05-23 07:05:42.027560 INFO AppDaemon: Added log: Diag
2020-05-23 07:05:42.034421 WARNING AppDaemon: config_dir: /home exists, but is not writeable, owner: root
2020-05-23 07:05:42.035766 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2020-05-23 07:05:42.041046 INFO HASS: HASS Plugin Initializing
2020-05-23 07:05:42.041191 INFO HASS: HASS Plugin initialization complete
2020-05-23 07:05:42.041403 INFO AppDaemon: Initializing HTTP
2020-05-23 07:05:42.041576 INFO AppDaemon: Using 'ws' for event stream
2020-05-23 07:05:42.047168 INFO AppDaemon: Starting API
2020-05-23 07:05:42.049315 INFO AppDaemon: Starting Admin Interface
2020-05-23 07:05:42.049485 INFO AppDaemon: Starting Dashboards
2020-05-23 07:05:42.050009 WARNING AppDaemon: css: /home exists, but is not writeable, owner: root
2020-05-23 07:05:42.050586 WARNING AppDaemon: javascript: /home exists, but is not writeable, owner: root
2020-05-23 07:05:42.056007 INFO HASS: Connected to Home Assistant 0.110.1
2020-05-23 07:05:42.069887 INFO AppDaemon: App 'hello_world' added
2020-05-23 07:05:42.070366 INFO AppDaemon: Found 1 total apps
2020-05-23 07:05:42.070586 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2020-05-23 07:05:42.081352 INFO AppDaemon: Running on port 5050
2020-05-23 07:05:42.088983 INFO HASS: Evaluating startup conditions
2020-05-23 07:05:42.093506 INFO AppDaemon: Got initial state from namespace default
2020-05-23 07:05:44.084011 INFO AppDaemon: Scheduler running in realtime
2020-05-23 07:05:44.085467 INFO AppDaemon: Adding /home/user/hass/docker_files/appdaemon/apps to module import path
2020-05-23 07:05:44.086507 INFO AppDaemon: Loading App Module: /home/user/hass/docker_files/appdaemon/apps/hello.py
2020-05-23 07:05:44.088251 INFO AppDaemon: Initializing app hello_world using class HelloWorld from module hello
2020-05-23 07:05:44.114133 INFO hello_world: Hello from AppDaemon
2020-05-23 07:05:44.114580 INFO hello_world: You are now ready to run Apps!
I was wondering if anyone can help me find what I’m missing or what I’m doing wrong.
