Is there a reason that i cant work out how to get ESPHome as an addon?
I can see it as an integration, but it asks for the node name etc, but i havent got that far yet?
I need the ESPHome to flash the board?
Am i missing something, please help, someone?
Thanks, Dan
Maybe i need to add that i’m running home assistant on unraid using a docker?
I seems you already have ESPHome installed. For everyone else it’s either
pip install esphome or docker pull esphome/esphome
In the beginning I ran ESPHome in the same Python virtual environment as Home Assistant. I now mostly run it on Windows Docker. There is no need for an add-on.
Note that the ESPHome documentation is not up to date. There is a docker version for Pi: esphome-armv7 and the ESPHome dashboard does run on the Window Docker port 6052.
