Home Assistant 0.44: ZigBee, OpenCV and DLib
![](upload://81nSRwAHBgSJdmRCtKtofTgCITn.png)
This release brings some great new integrations. The biggest one is the native ZigBee integration by Russell Cloran. This will allow Home Assistant to natively control Philips Hue lights without the need for a hub! (IKEA Tradfri lights not yet due to implementing a different profile)
Another great new addition is OpenCV by Teagan Glenn. So now you’ll be able to unlock all the cool stuff from OpenCV right in Home Assistant. And if OpenCV is not your style, you can try out the new DLib integration added by Pascal Vizeli in this release.
This release also includes a new component to dynamically generate RSS feeds based on a template. This means that any RSS widget on your phone, tablet or computer can now be used to show Home Assistant data!
And finally, for users of the config panel in the UI, we have fixed the issue with the group editor.
Enjoy!
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat. The release notes have comments enabled but it’s preferred if you use the former communication channels. Thanks.
Reporting Issues
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
New integrations
Release 0.44.2 - May 8
  • Fix opening add-ons in Hass.io store that are not installed (@balloob)
Release 0.44.1 - May 7
Breaking changes
  • Python Open Z-Wave made a release that fixed string processing. This was backwards incompatible. We have updated our code so you’ll have to update to the latest Python Open Z-Wave with this release. You can also wait one release, as next release we’ll introduce automatic installing of Python Open Z-Wave. (@keatontaylor - #7266) (climate.zwave docs) (breaking change)
  • InfluxDB configuration to blacklist domains has been updated to allow more features. (@janLo - #7264) (breaking change)
# New format
influxdb:
  exclude:
    entities:
       - entity.id1
       - entity.id2
    domains:
       - automation
  include:
    entities:
       - entity.id3
       - entity.id4
All changes
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2017/05/06/zigbee-opencv-dlib/
