Home Assistant 0.84.6 - New Install - Lovelace yaml location
Hi All,
Managed to brick my old home assistant box after some finger trouble, so I’ve reinstalled the OS, and got home assistant up and running again, however, I can’t find where the default lovelace config is being dished out from?
I have checked my config directory, and there is no ui-lovelace.yaml file in there, however, I am able to browse the lovelace page from the default installation. I have copied my existing ui-lovelace.yaml file into the config directory, but again I still see the default lovelace page without my configuration on there. I know the config directory is correct, as my configuration.yaml file is working just fine.
Home Assistant is installed via docker if that helps.
By default the lovelace config isn’t stored in a yaml file anymore. Check the last release notes for more details.
Super quick reply, thanks for that! - so basically, if all else fails, read the instructions! facepalm
Cheers for that - looks like my darksky is now broken, but I can sort that out! :slight_smile:
