Hi all,
I recently upgraded to home assistant 2021.11.5 from the 2021.10.1 and have the following situation.
Before upgrading I could see all cards just fine in all tabs.
After upgrading:
1 of my tabs (office) it shows 1 grid card but no the other cards.
When I try to use configure, it only shows 1 card I am able to configure
The other cards are missing
However, looking into the file with the RAW editor I can see the cards are present
I tried different themes, no success here.
Restoring to the previous version all is good and works fine
Any idea where I might look?
Thanks Petro,
sorry for the late reply, quite busy in the office
I updated before the update to 2021.11.1 and HASS says there are no cards needing an update in the frontend section.
I’ll update now and will look into the HACS potential updates and feed back to here.
Cheers
Dietger
Hi Petro,
altough it wasn’t any of the custom cards it kind of triggered the look out at integrations.
The Integration SMART-IR that wasn’t managed with HACS caused the issue, as part of the custom Grid card, it stalled the whole card and not only this particular within the grid.
Updated through services, restarted and all is perfect.
Thanks for the hint.
Cheers
Dietger
