Hi, i have a problem with the audio output of home assistant: in the previous versions there was an hassio_audio container that if you don’t want to get the audio output used from home assistant you can disable it. Now since I upgraded to latest versions of home assistant, the hassio_audio container doesn’t exist anymore and I get the audio output used. Now I cannot use it for other services (in my case raspotify).
Any suggestions?
