Hi Recte,
I havent tried first step.
2. I copy the logs to txt-file.
3. i can ping, and it responds
4. Not yet.
Log File:
2023-04-17 20:10:17.127 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration apex which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:17.128 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nordpool which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:17.129 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration midea_ac which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:17.129 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration solis which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:17.129 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration entsoe which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:17.129 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:17.129 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mbapi2020 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:17.129 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration dlink_hnap which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-04-17 20:10:18.147 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-04-17 20:10:18.184 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=20043 from 2023-04-17 17:10:06.424842)
